Author Topic: Heidenhau K60 versus Mitas E07  (Read 78653 times)
Offline donaldb
« on: August 26, 2012, 07:58:41 am »
Finally got new K60 on my tenere after mitas E07 was worn out.
Done about 1500 km on them, on road and off.
Dry tar:
The K60 on tar is definitely better, feels more stable and sure footed. Corners really well and good positive feedback. Does have a higher whine though. The mitas did corner well, had no faults with tar. Got serious whine after about half way through their life.
Wet tar:
The K60 does have a habit of stepping out, and have to be a bit weary on entering corners, once in the corner, found them to be more stable.  The Mitas performed well in the wet.
Gravel:
K60 performs well, bike hits traction control easily though, always on tc2 on the gravel. The mitas is delicately far more secure on the gravel, and found it does not hit traction control as easily, but gets going instead. Both are very secure around corners.
Wet gravel:
K60 slips far easier than the Mitas, which is far more secure and does not side step like the K60.
Mud:
K60 is side ways, got to be careful on the throttle. Mitas had very little snake effect. Both cases will have traction control responding.
Mileage:
Have never run the K60 to end yet, the Mitas gave me 8000km, which I am sure the K60 will out do that with ease.
front:
No problems with the front tyres. Both seemed very much the same.
Decision:
Keeping the K60 front, but will be removing the rear and returning to Mitas. The mitas might not give me the mileage, but prefer the performance by far. Anyone in South Africa wanting to buy a good second hand rear K60?
Sent from my GT-N7000 using Tapatalk 2
Offline donaldb
Re: Heidenhau K60 versus Mitas E07
« Reply #1 on: August 26, 2012, 09:12:46 am »
Added above to thread "best tyre"
http://www.yamahasupertenere.com/index.php?topic=2812.0
This can be deleted
« Reply #2 on: August 26, 2012, 12:08:20 pm »
What tire pressure are you running in the K60's ?
Offline donaldb
« Reply #3 on: August 26, 2012, 12:45:36 pm »
250 kpa, as per tyre spec, and am mostly loaded as well.
Mitas run at 295
« Reply #4 on: August 26, 2012, 01:19:45 pm »
Before you take them off, I would suggest you try  262 (F)  &  276 (R)
It should fix your issue.
« Last Edit: August 26, 2012, 01:21:27 pm by ~TABASCO~ »
Offline donaldb
« Reply #5 on: August 26, 2012, 02:33:11 pm »
Will try that, however, if I understand correctly, the harder the tyre, the more likely it is to slip out.
« Reply #6 on: August 26, 2012, 03:00:08 pm »
Give it a try.......
Offline Mikef5000
    • Mikef5000
« Reply #7 on: August 27, 2012, 10:38:54 am »
Thanks for the review. I was seriously considering the Mitas before I landed on the K60. Interesting that you're going to use the K60 front and Mitas rear; I was going to do the opposite! The Mitas front looked very similar, and cost $30+ less.
I went with the K60 instead due to the mileage, but now that I read your review (and that the K60 is better on pavement) I'm not even considering the Mitas any more.
One of these times you should try the E-07 Dakar, and report if your mileage is any better!
2012 Super Tenere
2008 WR250R
www.Mikef5000.com
Offline RockyDS
« Reply #8 on: August 27, 2012, 01:00:43 pm »
I would have expected advising lowering the pressures for off road use, so I wondered what the reasoning is behind these higher pressures; 38 psi front and 40 psi rear when the K60 tires specify max 36 psi on the sidewalls??
I guess I'd be leery of exceeding the manufacturers maximums.
Super Ténéré - Yukon 2012 - Ouray 2013 - PCH 2014
« Reply #9 on: August 27, 2012, 01:10:21 pm »
 I would agree, but I talk with Heidenau everyday. They have said its fine...   Ive personally been on that pressure for 10K miles.. Tires work fantastic, and have worn fantastic...  Working with the manufacture and riding them for 10K,  they work great for me...
« Last Edit: August 27, 2012, 02:17:59 pm by ~TABASCO~ »
Offline RockyDS
« Reply #10 on: August 27, 2012, 01:33:39 pm »
I would agree, but I talk with Heidenau everyday. They have said its fine...   Ive personally been on that pressure for 10K miles.. Tires work fantastic, and have worn fantastic...  Working with the manufacturing and riding them for 10K,  they work great for me...
Sounds good.  The max pressure is measured cold and for a specified load anyway, so not an absolute max.
Offline donaldb
« Reply #11 on: September 02, 2012, 03:51:25 pm »
Ok, tried it at 275, slipped consistently. Tc2 was on and the light flickers far too regularly, and I use touring mode when not on tar.
Dropped the pressure down to 230 and the tyre works a lot better.
Although still not as good as the Mitas, but very operational.
Under hard rear breaking, the tyre trends to snake a bit, which the Mitas did not, but is controllable.
My worry now is running the lower pressure on tar and safety. Will it not get to dangerously hot.
Still considering returning to the mitas for the rear.
Offline zartenere
« Reply #12 on: September 02, 2012, 04:52:49 pm »
my mitas e07 cracked at 1500km.i send it to importer he told me it is cold cracks.i told him to put it in his crack
Offline donaldb
« Reply #13 on: September 02, 2012, 10:23:15 pm »
Yes, mine also did have cracks in front of the treads in the center, at around 2500km. Also called the importer.
They were not deep, bit of a worry, but after 8000km, they had not got any worse.
Friend has them on his, and done around 4000 km, no cracks.
Offline AL-58
« Reply #14 on: April 16, 2013, 05:21:53 am »
I fitted new Mitas E-07 front and rear.  I got caught with a front tyre that loses air and it turns out that its been recalled anyway.  Have put a K-60 on the front now till the Mitas is replaced.
In comparison I don't like the feel of the Heidenau, its more stable yes but the Mitas wasn't unstable and turned into corners much easier than the K-60.  Havent seen dirt or rain yet.
Al
2010 Super Tenere
1987 BMW K100RS/HRD sidecar
Past bikes:
2010 Yamaha Super Tenere (RIP), 2008, BMW F800GS, 2002 TDM900, 1989 BMW R80G/S, 1997 Honda VTR1000F, 1993 BMW R1100GS, 1991 BMW K100RS 16v/HRD Sidecar, 1997 BMW R1100R, 1996 Triumph Trophy 900, 1986 BMW K100RT/HRD Sidecar, Yamaha XJ750 sidecar, 1991 Yamaha TDM850, 1991 BMW R100GS, Suzuki PE175X, 1982 Honda CB750F2C, 1986 BMW K100RT, Suzuki DR500S, 1984 Suzuki GSX1100EFE, Honda CR250 Elsinore, 1984 Yamaha XJ900RL, 1982 Honda CB750F, 1982 Yamaha XT550J, 1973 Yamaha TX500, Suzuki TC185  (But does it really matter?)
Last post June 04, 2012, 05:16:44 pm
by dcstrom
Last post September 17, 2012, 01:16:37 pm
by Alan
Last post October 29, 2013, 09:55:20 pm
by snuffcityrider
Last post August 12, 2015, 03:09:34 am
Last post July 31, 2016, 10:22:52 am
by craigd
