Author Topic: GPS mount  (Read 557 times)
Offline LittleWalleez
GPS mount
« on: April 29, 2018, 01:11:10 pm »
Where's the best place you've found to mount a gps?  On the hanlebars?  the windscreen mount?  How's the vibration?
I need to mount my garmin 610 and have a ram mount.  Curious about everyones experiences with this! :question:
Offline BigBob
Re: GPS mount
« Reply #1 on: April 29, 2018, 01:25:51 pm »
actually no idea why I have this pic!  But I like it on the bar with ram mount. Solid and easy to reach. Not in the way of instruments or single track right in front.
Member of Mid-Iowa Star #210
2014 Super Tenere ES
2010 Stratoliner Deluxe
Re: GPS mount
« Reply #2 on: April 29, 2018, 01:57:03 pm »
Me too. I just made a special bracket, where the cradle is directly monted.
Offline RCinNC
Re: GPS mount
« Reply #3 on: April 29, 2018, 02:03:52 pm »
Mine is mounted to the accessory bar on the windshield mount.  There's too much vibration without some sort of reinforcement to the mount, so I got a set of reinforcing bars from a member on the forum (Propsoto).  The cradle for the GPS is a RAM cradle (the GPS is a Nuvi 2455).  It's attached to the accessory bar with the standard RAM double socket, and a homemade ball mount.  I did modify the adjustment knob of the RAM double socket so it would be easier to tighten; it's a little confined in the space between the mount and the windshield to get my hand in there.  The GPS plugs into a USB port on a homemade shelf mounted above the instrument pod; I made a bracket that allows me to screw the USB power cable from the GPS into the USB outlet, so it won't come loose from vibration while riding.
2014 Yamaha Super Tenere
2012 Suzuki DL650 (traded)
2004 HD Road King Custom (sold)
2000 Yamaha Road Star 1600 (traded)
1994 Yamaha Virago 1100 (traded)
1982 Honda V45 Sabre (traded)
1984 Kawasaki 440LTD (sold)
Re: GPS mount
« Reply #4 on: April 30, 2018, 01:43:28 am »
Here is a DIY bar for Gen1 S10.
Made of AL sheet metal frame and plastic water pipes with end caps riveted to the AL frame.
Offline Stef
Re: GPS mount
« Reply #5 on: May 04, 2018, 10:52:02 pm »
I've got my Zumo and a cellphone cradle on my accessory bar.  They're rock solid.
Offline Hfjeff
Re: GPS mount
« Reply #6 on: May 05, 2018, 11:09:48 pm »
I used a TechMount directly on the handlbars in the middle and it was perfect and solid.  However I just installed a Helibar riser block and can no longer mount here.  So I am looking at the cross member of the Madstad bracket.
« Last Edit: May 05, 2018, 11:15:05 pm by Hfjeff »
2016 Yamaha Super Tenere ES
2007 Yamaha Zuma (wifes ride but I maintain)
Offline EVLED
  • Bike riding nutter
    • My Blog
Re: GPS mount
« Reply #7 on: May 06, 2018, 02:51:05 am »
I've got the SW-Motec vibration damped jobbie.  I had to make up a little plate to raise the GPS cradle up a bit higher so that the dash wasn't obscured:
'08 Concours 14, '13 Super 10
Offline fredz43
Re: GPS mount
« Reply #8 on: May 16, 2018, 01:00:26 am »
Greetings, Where did you get those 2 gadgets that clamp to the accessory bar? I want to locate the display for my TPMS there.
Thanks.
You're only young once.
BUT, you can be immature forever! :-)
In theory, there is no difference between theory and practice.
In practice, there is.
Offline Stef
Re: GPS mount
« Reply #9 on: May 16, 2018, 01:06:24 am »
https://www.rammount.com/part/RAM-B-408-37-62U
Offline fredz43
Last post December 18, 2011, 07:13:17 am
by Tenerator12
Last post October 27, 2011, 02:25:06 pm
by doctorj
Last post December 02, 2012, 06:14:58 pm
by BaldKnob
Last post March 24, 2013, 08:42:40 pm
by tomatocity
Last post September 21, 2015, 08:05:28 am
by camardelle
