Author Topic: Moto Guzzi V85 Adventure bike  (Read 2662 times)
Re: Moto Guzzi V85 Adventure bike
« Reply #45 on: April 29, 2018, 09:48:37 am »
This article says the final production version should be shown at EICMA in November with sales in January and priced from 11-12,000 Euros. The US market typically gets bikes at lower prices than the Europeans so the full retail price of 11000 Euros is currently $13,400.
https://imotorbike.my/news/2018/04/moto-guzzi-v85-to-go-into-production
Offline smudger
« Reply #46 on: April 30, 2018, 03:47:07 am »
Does anyone have an idea of what the seat height will be?
Lets get Amongst it!
Offline Madhatter
« Reply #47 on: May 02, 2018, 10:44:38 pm »
to short for some to long for many....
« Reply #48 on: May 03, 2018, 08:02:01 pm »
Hmmmm....interesting....but, no thank you.  My Tenere is stuck with me.  ::001::  ::022::
Offline smudger
« Reply #49 on: May 11, 2018, 02:39:10 am »
    There you go,
   Moto Guzzi V85 (2018)
  Technical Data
ENGINE AND DRIVE TRAIN
Engine type V
Cylinders 2
Strokes 4-Stroke
Valves per cylinder 2
Cooling Oil-air
Displacement 853 ccm
Bore 84 mm
Stroke 77 mm
Max. Power Output 55 HP
Rpm at Max. Power Output 6250 rpm
Max. Torque 62 Nm
Rpm at Max. Torque 3000 rpm
Compression Ratio 10.5
Fuel system Injection
Starter Electric
Clutch Type Toughened
Ignition Digital
Final Drive Prop shaft
Transmission Type Gearshift
Number of gears 6
CHASSIS
Frame Steel
Frame type Double cradle
Steering axis angle 63.4 degree
Trail 116.1 mm
SUSPENSION FRONT
Front suspension Telescopic fork
Diameter 40 mm
Travel 130 mm
SUSPENSION REAR
Rear suspension Swing arm
Material Steel
Shock absorber Monoshock
Travel 97 mm
Adjustment Preload
BRAKES FRONT
Front brake Single disk
Diameter 320 mm
Piston Four pistons
Brand Brembo
BRAKES REAR
Rear brake Disc
Diameter 260 mm
Piston Double piston
Brand Brembo
ASSISTANCE SYSTEMS
Assistance systems ABS, Traction control
DIMENSIONS AND WEIGHTS
Front tyre width 130 mm
Front tyre height 90 %
Front tyre diameter 16 inch
Rear tyre width 150 mm
Rear tyre height 80 %
Rear tyre diameter 16 inch
Length 2134 mm
Width 722 mm
Height 1110 mm
Wheelbase 1480 mm
Seat Height from 775 mm
Kerb Weight (with ABS) 200 kg
Fuel Tank Capacity 15 l
License A
ERRO MOTO   Tel.: 03332/65440   E-Mail: office@erromoto.at   Josef Teubl
Offline tallpaul
« Reply #50 on: May 11, 2018, 03:23:31 am »
16 inch front tyre?! Are we back on '80s sports bikes?
Obviously the front wheel size is a typo but the 15 litre tank makes this sound more like a styling exercise rather than a serious off road bike.
« Last Edit: May 11, 2018, 03:26:41 am by tallpaul »
« Reply #51 on: May 11, 2018, 10:54:28 am »
55 horsepower?
« Reply #52 on: May 11, 2018, 11:20:32 am »
55 horsepower?
Official website quotes it at 80hp, which is about right based on the the other Guzzi models
Offline cycledelic relic
« Reply #53 on: May 11, 2018, 03:35:54 pm »
These specs look more like the current Roamer ....I doubt if they pertain to the V85 adventure bike
    There you go,
  Technical Data
Engine type V
Cylinders 2
Strokes 4-Stroke
Cooling Oil-air
Bore 84 mm
Stroke 77 mm
Max. Torque 62 Nm
Starter Electric
Ignition Digital
Number of gears 6
CHASSIS
Frame Steel
Trail 116.1 mm
SUSPENSION FRONT
Diameter 40 mm
Travel 130 mm
SUSPENSION REAR
Material Steel
Travel 97 mm
Adjustment Preload
BRAKES FRONT
Diameter 320 mm
Piston Four pistons
Brand Brembo
BRAKES REAR
Rear brake Disc
Diameter 260 mm
Brand Brembo
ASSISTANCE SYSTEMS
Length 2134 mm
Width 722 mm
Height 1110 mm
Wheelbase 1480 mm
License A
Sent from my LGL62VL using Tapatalk
« Reply #54 on: May 11, 2018, 05:15:42 pm »
Sorry, but I also think this isn't correct.
130mm suspension travel front....97mm travel back....  No no.
« Reply #55 on: May 11, 2018, 05:23:02 pm »
While it'd be sorta in the range of pure street bikes that's 3.87" front and 5.1" rear, which does sound too little for a bike intended for occasional off-road.
For comparison, the Norge Sport is 4.7" and 5.5"
Offline Madhatter
« Reply #56 on: May 12, 2018, 07:39:12 am »
that tech list does not even match the photos of it.... every thing ive heard says 85 hp 19inch front and from photo at least 8 inches from pan to ground.... and it just looks right..... it will do well at starbucks.....
« Reply #57 on: May 12, 2018, 09:03:01 am »
Now that you mention it, that is a list for a totally different and older model. The 16" tires, the hp matching the V9 motor, and the suspension travels are used for some of their streetbikes.
Offline Madhatter
« Reply #58 on: May 12, 2018, 05:54:34 pm »
it is a good looking bike , it has a simplicity in its looks that is fresh , not much plastic . might be a great bike and it will get attention I think...
Last post May 20, 2011, 11:39:03 am
by MotorcopBBQ
Last post July 07, 2016, 05:38:57 pm
by Andylaser
Last post May 09, 2016, 03:01:29 am
by Stridey
Last post March 14, 2016, 03:43:09 pm
by Daviedevs
Last post November 13, 2017, 09:20:17 pm
by abong
