Author Topic: Issue: Idling at 2500-2900rpm when in gear  (Read 2139 times)
Offline zoeed
« on: January 08, 2017, 10:49:39 pm »
Hi All,
I Just got off my bike, after a short ride to work. It had been in the garage for about 20 days.
My S10 has been perfect in the 20000miles that I have ridden, until this morning.
While in gear, it idles high around 2500-2900 rpm when in gear (all gears)
In neutral it would go back to its normal idling speed.
I noticed that my bike lost compression a few times when I blipped it during the first few miles of my morning ride.
I have a number of mods done to it which could change the stock parameters:
O2 sensor eliminators
Two Brothers exhaust
K&N Air Filter
My country recently converted to 92RON & 97RON fuel
I have come up with some answers to my problem through searching:
1- Could be a spark plug issue (replace plugs)
2- clutch dragging (install new plates)
3- fuel filter choke (replace fuel filter)
4-fuel itself (add fresh fuel)
Any help in identifying the problem would be great .
Thanks in advance
Regards
Re: Issue: Idling at 2500-2900rpm when in gear
« Reply #1 on: January 09, 2017, 12:17:51 am »
Could be as simple as replacing the battery, others have found that replacing with a new or the higher YTS14 battery cured their idle issues, worth a shot.
Offline zoeed
« Reply #2 on: January 09, 2017, 05:53:28 pm »
Ooo...
I put in a Shorai 18amp couple of months ago.
Maybe the battery needs a deep cycle recharge.
Btw the thing cleared itself out on my way back.
A low battery voltage may have charged one way to work....
I'll need to wait and see what it does in a few hours when I go to work again.
« Reply #3 on: January 10, 2017, 09:55:04 pm »
"I noticed that my bike lost compression a few times when I blipped it during the first few miles of my morning ride."
Could you explain this further , sorry I simply don't understand.
« Reply #4 on: January 10, 2017, 10:26:20 pm »
Sounds like the Throttle Sync is out.
Offline trainman
« Reply #5 on: January 11, 2017, 05:34:51 am »
long shot but simple to check, I know clutch position affects mapping at least on gen 1 bikes, check clutch lever switch ok
Offline JRE
  • Going to hell on scholarship
« Reply #6 on: January 11, 2017, 09:01:46 am »
This was my first thought...
Joe
I'm silently correcting your grammar
2014 Yamaha Super Ténéré ES
2009 Honda XR650L
« Reply #7 on: January 11, 2017, 01:22:54 pm »
He said it lost compression, How could throttle sync affect compression ?
Offline OldRider
« Reply #8 on: January 11, 2017, 02:30:58 pm »
I don't think he's talking about compression in the same way we do. He said it lost compression when he bliped the throttle, maybe lost power ???
« Reply #9 on: January 12, 2017, 12:56:24 am »
Hi idle in gear, normal in neutral? Anything I can think of would have the same idle throughout. I can't see how a battery would affect idle tho. Once started you can disconnect the battery and not have an effect on idle.
« Reply #10 on: January 12, 2017, 05:50:46 am »
Don, I've had a different experience, if I disconnected the battery the bike shuts down, could it be that as in EU we have immobilisers and once power is cut then ecu shuts down?
« Reply #11 on: January 12, 2017, 11:44:17 am »
Could the ECU be raising idle speed in an attempt to maintain system voltage in the case of a flat battery?
« Reply #12 on: January 13, 2017, 01:06:10 am »
It's not that smart.
Offline Kevhunts
  • "For every one you see, you probably missed three"
« Reply #13 on: January 13, 2017, 01:51:39 am »
It's not? Does the ECU not control the voltage regulator? Idle speed control? Ignition timing & advance? Newer gen turn signal rate, grip heaters?
I'd say that's pretty smart.
FYI...Disconnecting the battery on a modern ECU controlled system that is running is simply asking for ECU self destruction.
« Last Edit: January 13, 2017, 01:56:18 am by Kevhunts »
The act of riding is a form of meditation, because the concentration that's required to safely ride a motorcycle tends to focus the mind in a way that eliminates other mental distractions that might interfere with the mission.
« Reply #14 on: January 13, 2017, 03:25:34 am »
I take it that he meant 'compression', or, felt a loss of power.
Last post November 27, 2011, 06:35:21 pm
by X5
Last post November 24, 2011, 02:36:54 pm
by Blue_eyes
Last post December 06, 2012, 01:00:11 pm
by crazyeights34
Last post August 15, 2013, 09:18:27 pm
by fredz43
Last post December 21, 2015, 03:32:03 pm
by mileageman
