Author Topic: ACD Skidplate welding  (Read 1316 times)
Offline marouan0001
« on: January 05, 2017, 05:39:40 pm »
Ok Guys the first piece of my new transformation kit just arrived today.
The infamous ACD skid plate... and this thing is humbly described "JUST HUGE".
It came well packed and quickly. Thumb up for the delivery time. I ordered it from ACD on the 26 december and it was delivered to me in Stockholm on the third of january, free of charge.
i have attached  some pictures.
The first thing  i ´m concerned about is the sharp edges when , we are talking about knife sharp here (se the pics) and the quality of the weld that dosen´t seem to be penetrating all the way on the joints.
to be continued...  ::022::
[This thread has been split from another thread into it's own topic - CW]
« Last Edit: January 07, 2017, 01:05:03 pm by Checkswrecks »
Offline Kurgan
Re: Re: the most beautyful S10 i have ever seen
« Reply #1 on: January 05, 2017, 06:42:05 pm »
The edges, not impressive as far as a finished product.  Although you shouldn't have to, you can remedy that yourself with some effort and time in an afternoon.
The weld, however, based on the angle of the pic you've shared, that looks like a problem.
The 2 plates weren't fitted / jigged together well leaving that fitment gap at the top that they didn't correct when it was welded.  They should have done another weld pass from the inside to fill that gap and leave a weld at least as thick as the original plates.
« Last Edit: January 05, 2017, 06:47:12 pm by Kurgan »
Jim
2013 Super Tenere - White/Red
Offline Checkswrecks
  • Ungenear to broked stuff
« Reply #2 on: January 06, 2017, 09:24:50 am »
The ACD plate is MUCH easier to get off and on for oil changes if you replace the two front engine mount bolts with studs.
http://www.yamahasupertenere.com/index.php?topic=5744.msg191672#msg191672
Damascus, MD
XTZ1200, KTM 690R
Offline marouan0001
« Reply #3 on: January 06, 2017, 10:02:34 am »
Thanks Kurgan for confirming my soupcons. here is a pic from another  angle so that everyone see what im talking about.
Offline Kurgan
« Reply #4 on: January 07, 2017, 10:34:50 am »
Fit up between those pieces doesn't look bad in the second pic, but that one token weld on the back side is not impressive.  They could/should have done more.
Jim
Offline yoyo
« Reply #5 on: January 07, 2017, 11:29:39 am »
I'd contact the supplier, send some pics and register your concerns just in case it fails in the future. Agree on the inside weld, I tack isn't enough on that joint, it should run full length.
Sent from my SM-G930F using Tapatalk
Offline marouan0001
« Reply #6 on: January 07, 2017, 04:38:32 pm »
Tanks Checkswrecks the studs are a super idea for the ACD skid plate.
Offline Mikeybikey57
Re: ACD Skidplate welding
« Reply #7 on: January 07, 2017, 04:59:50 pm »
In comparison to the welds on my ACD plate, these look poor and very much half-finished. Maybe you have what we Brits refer to as a "Friday afternoon" skid plate (rushed to finish in order to get off home early). I'll second the idea of using studs to mount the plate at the front too. It makes removal and re-fitting a lot easier, especially as the threads in the bolt holes are very fine and easily crossed. If you have any trouble getting hold of the right studs, let me know and I'll post you a pair. My supplier would only sell the right threaded steel rod to me in 1 meter lengths and I have quite a bit left over. ::)
« Last Edit: January 07, 2017, 05:01:55 pm by Mikeybikey57 »
"There's no point in worrying about life.......you'll never get out of it alive" ~ Sigmund Herzuka
Offline Xclimation
« Reply #8 on: January 08, 2017, 10:05:07 am »
I'd be sending it back for an exchange! I'm NOT a welder but that looks halfed-azzed!
2015 Super Tenere Power Commander PCFC, Catless OEM headers, Delkevic slip-on, Uni-filters, Modified Airbox, Altrider Crash bars and skid plate, Flat seat mod. Dash in-fill, Nighteyes LED headlight bulbs, SW motech tank bag, Madstad windshield bracket, Parabellum/Give Airgflow windshield (Using stock windshield mostly) Touratech Headlight guard, Rox Risers, RideonAdv. extended brake/clutch lines
Offline marouan0001
« Reply #9 on: January 08, 2017, 10:18:20 am »
Thanks a lot Mikeybikey57 i appreciate really you proposition. Is it possible for you to mail it to sweden? By the way here in sweden we call it monday exemple  ::015::
Offline UpToNoGood
« Reply #10 on: January 08, 2017, 12:24:45 pm »
Tabasco makes a skid plate to resolves all the issues you discussed and will allow you to change the oil with out removing the plate.  One and done if you ask me.
http://rideonadv.com/
2015 ES Tenere
RideOnADV skid plate, Arrow headers & Exhaust, Anthony ECU Flash, Altrider luggage rack, Altrider crash bars, Altrider Upper Crash Bars, Altrider U-Joint guard, Altrider Kick stand foot, Altrider fork guards, Altrider Master Cylinder Guard, Baja Squadron Pro Lights w/skene dimmer, ROX risers & longer Clutch/Brake line, Pivot pegz, Heidenau K60, Madstad, Wunderlich Mirror riser, Side wind deflectors, Jesse Panniers
« Reply #11 on: January 08, 2017, 12:42:03 pm »
In the end, how does it perform? If it doesn't the company does have a warranty.
We have a LOT of members with ACD skid plates, including me, and some really have put their plates through a beating. I can't think of anybody ever who had one fail or even mentioned a cracked weld.
Damascus, MD
XTZ1200, KTM 690R
Offline Blind Squirrel
« Reply #12 on: January 08, 2017, 06:28:09 pm »
I'm not a professional welder, but I am currently taking welding classes at my community college. That is a bad weld. No penetration on one side of the base metal. I would send it back.
- Scott
Chesapeake Va.
Offline marouan0001
« Reply #13 on: January 09, 2017, 01:55:00 am »
I have contacted ACD with some pics now and i´m waiting for an answer.
Lets see how it turns out.
Offline marouan0001
« Reply #14 on: January 11, 2017, 02:23:20 pm »
Still have no answer from ACD Europe and I'm starting to wonder if they the support is as good as the the USA division. Untill now I'm really not satisfied with this skid plate that seems to be more of a liability then an asset
Skickat frĺn min iPad med Tapatalk
Last post November 30, 2011, 04:11:03 pm
by plugugly
Last post May 27, 2015, 06:09:58 pm
by caillou
Last post June 18, 2015, 12:04:58 am
by fredz43
Last post July 28, 2015, 09:28:05 pm
by jbrown
Last post January 07, 2017, 01:05:23 pm
