Author Topic: Rear End / Final Drive Oil  (Read 35532 times)
Offline immigrant
« on: September 07, 2011, 10:11:01 am »
Got the yamalube SAE80W90 drive shaft gear oil from dealer today. they were not sure if this is the correct oil for the shaft drive. Can you guys confirm that this is correct. it does not have any of the other numbers printed on it as what the user manual  states. I see on the yamaha website there is also friction modified shaft drive gear oil 80W90 I a not sure which one to use?
You really only  have two choices in life: stay in bed, or get up and go to work!
Offline Twisties
Re: 2 types of yamalube for final drive - which one do I use?
« Reply #1 on: September 07, 2011, 10:27:38 am »
My dealer didn't have the specified straight 80 weight oil so I used what I had already:
http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Fully_Synthetic_Gear_Lube_75W-90LS.aspx
2012 Yamaha Super Tenere
2007 BMW R 1200 RT
2012 Suzuki DR650 SE
Offline Koinz
    • Visited
« Reply #2 on: September 07, 2011, 10:39:30 am »
Either one is probably fine. I'm sure the Friction Modified stuff is more expensive. How deep are your pockets.  :D :D
2012 Raven Super Tenere
1985 Yamaha XT 600
1987 KLR 650
Offline Kevhunts
  • "For every one you see, you probably missed three"
« Reply #3 on: September 07, 2011, 10:46:15 am »
All my dealer had on the shelf at the time was the friction modified formula. It states on the bottle it can be used in regular final drive applications.
I don't remember the exact cost but it was no more than a quart of yamalube dino oil.
The act of riding is a form of meditation, because the concentration that's required to safely ride a motorcycle tends to focus the mind in a way that eliminates other mental distractions that might interfere with the mission.
Offline canyonman
« Reply #4 on: September 07, 2011, 12:55:08 pm »
Any brand gl4 or gl5 80/90w oil is fine. I happened to pick up the bel-ray stuff, been using the same in the FJR for 45,000 miles.
2007 FJR
Offline immigrant
« Reply #5 on: September 07, 2011, 06:55:13 pm »
Thanks for the info. will get the yamalube friction modified shaft drive lube
Offline NFTEN
« Reply #6 on: September 07, 2011, 07:00:58 pm »
I just changed the final drive with Mobil 1 Synthetic Gear Lube LS 75W-90. Did not trust the Yamaha 80w90. Why I did not trust the Yamaha stuff, not sure maybe it was the lack of documentation. The Mobil 1 stuff is documented, tested, on various websites around the web, and used in very harsh heavy duty applications such as work pickups, and high performeance cars. I'm not a mobil employee. If I could access it I would be using a Amsoil products.   :)    also the mobil 1 stuff as friction modifiers
2012 Super TENERE
Sold - 2005 Kawasaki KLR650 19k KM
Offline AlsoRan
« Reply #7 on: September 07, 2011, 10:15:52 pm »
Just purchased some Yamalube Shaft Drive Oil Exclusive from my dealer. The bottle indicates "exclusively for FJR1300 and VMAX 1700" and for "most severe conditions", but I am worried now that it may not be the correct weight as the dealer could not verify. Am I reading too much into this? Thanks for the help...
« Last Edit: September 07, 2011, 10:21:49 pm by AlsoRan »
Offline markjenn
« Reply #8 on: September 08, 2011, 12:44:03 am »
This sounds like the expensive synthetic lube that is supposedly superior to the regular GL5 stuff Yamaha sells.  I recall some arguing on the FJR forums whether this more expensive stuff was required or just recommended.  My take is that either would work fine in the FJR and since the S10 specs basically the same gear oil, I don't see any reason it wouldn't work fine in the S10.
And doesn't it say GL5 and the weight on the bottle?  If it's GL4/GL5 and close to the spec'ed weight (80W-90) it is acceptable to Yamaha.  As to what is "optimal" or "cost effective", I'll let others carry on about this.
- Mark
Offline tomatocity
« Reply #9 on: September 08, 2011, 12:47:47 am »
http://www.google.com/search?q=yamalube&sourceid=ie7&rls=com.microsoft:en-us:IE-Address&ie=&oe=&rlz=#sclient=psy&hl=en&rls=com.microsoft:en-us%3AIE-Address&source=hp&q=yamalube+final+drive&pbx=1&oq=yamalube+final+drive&aq=f&aqi=&aql=&gs_sm=d&gs_upl=21219l26194l2l26257l19l11l0l0l0l4l645l2773l0.5.4.1.0.1l11l0&bav=on.2,or.r_gc.r_pw.&fp=422aca6f1b1d5ac1&biw=1093&bih=546
You are not alone. Looks like there is a lot of discussion and information.
« Last Edit: September 08, 2011, 12:57:59 am by tomatocity »
Tim
2015 Yamaha Super Tenere, XTZ12EFCR, Candy Red, #112, 5/23/2015
2005 KLR685
2012 Yamaha Super Tenere, XTZ1200, Impact Blue, #027, 7/31/2011 (sold)
Offline hANNAbONE
  • ...Patiently Waited...
    • Bahnsturmers M/C Club
« Reply #10 on: September 08, 2011, 05:50:46 am »
throw some Mobil1 in there and call it good... ::021::
hANNAbONE
'12 Yammy SinisterBlack Supa10
...where 421 and 50 kiss...
* veho tutus, meus frater *
Offline tomatocity
« Reply #11 on: September 08, 2011, 06:09:59 am »
That is what most of us would do but that is not what they are concerned with. They want to know what Yamalube product is correct. I am going to ask the parts manager I buy from. He has been doing Yamaha parts for 35+ years.
Tim
2005 KLR685
Offline ColoRider
« Reply #12 on: September 08, 2011, 07:32:15 am »
Welcome to the Forum! Please post an intro in the "Member intros" area.  What color Tenere did you get?
 ::004::
Rod ~ Die Hard
'15 DL650XT
'15 XTZ12EF (GBNF)
'12 XTZ12BL (GBNF)
Enjoy Life Today
Yesterday Is Gone
Tomorrow May Never Come
My SPOT
Offline Twisties
« Reply #13 on: September 08, 2011, 10:00:36 am »
Agreed.  Why are so many saying here that Yamaha specifies 80w90?  My owner's manual clearly states straight 80 weight.  So far as I can see there is no such thing from Yamaha, or elsewhere.
For me the relevance of the question is warranty protection.  Although any brand hypoid GL-4 or GL-5 will meet the warranty requirements, it is not clear you can change weights from what Yamaha specify, and they have made a hash of it by:
1.  Specifying a grade that is apparently unobtainable,
2.  Failing to label their own products properly with weight and api specifications.
3.  Marketing similar products on a model specific manner and then failing to specify clearly which we should use.
I am in complete agreement that in so far as lubricating the final drive pretty much any oil in the general weight range and correct api spec will work fine.
2007 BMW R 1200 RT
Offline Jakeboy
  • What a long, strange trip it's been.
« Reply #14 on: September 08, 2011, 10:42:58 am »
My dealer didn't have any of the Yamalube gear oil in stock, so I bought the Honda gear oil that's recommended for the GW, ST and their shaft drive cruisers.  That was good enough for me.
They did have Amsoil 75W-90 synthetic gear oil, so I bought a quart of that for future use when I go to synthetic.
BTW, I check the oil level in the engine,  final drive and visually look at the FD and rear wheel area frequently, just for peace of mind.
Dave
I'll run and get the beer if you pay for it.
Last post February 26, 2014, 10:29:52 am
by Juan Valderrama
Last post June 05, 2014, 01:30:09 am
by Mzee
Last post August 08, 2012, 09:06:56 pm
by troll
Last post November 29, 2011, 05:10:33 pm
by markjenn
Last post June 10, 2016, 06:44:19 am
by Dogdaze
