Author Topic: windshield riding, whats your style?  (Read 1316 times)
Re: windshield riding, whats your style?
« Reply #15 on: October 04, 2017, 01:57:04 pm »
Quote
Quote from: Xclimation on October 03, 2017, 08:35:58 pm
I like some wind, but not to the point where turning my head is a chore.
^this
I like to look a couple of inches over the windshield. The wind goes over my helmet and I have a clear line of sight.
+1 to all the above.
I use a Shoei Hornet X2, with a sun visor.  I need protection from wind and buffeting to not allow that visor to yank my head / neck around.
I use: OEM standard screen and brackets, MRA X-creen Tour, OEM side wings, and a windshield bracket brace made by an inmate on this forum.
The combination works well for me (6' 0", lowered OEM seat) in all weather.
« Last Edit: October 04, 2017, 01:58:51 pm by mebgardner »
Offline RicoChet
« Reply #16 on: October 04, 2017, 02:02:47 pm »
I've got the Yamaha Tall windscreen with a small extra winshield on the top of that attached to the top that keeps all the wind off my head and body, and I absolutely freaking love it.
Current Bike: 2016 Yamaha Super Tenere ES & 2012 Triumph Rocket III Roadster
Offline Terminus
« Reply #17 on: October 05, 2017, 08:10:59 am »
Really, nobody has problems with side wind or traffic turbulence with available windshields?  ???
Guess it's just me!  :'(
You are not alone.  Driving in traffic especially on a busy expressway the air is very turbulent due to all of the other cars and trucks.  That was the main reason I got the Madstad and the larger Madstad windshield.  Now when I am in that traffic I can put the shield all the way up and the buffeting is gone.  The sidewind though.....not so much.  I think you would have to have a  very wide windscreen to block that sidewind... I think I have seen on this forum that really wide screens can hit the handle bars.
Red 2015 Yamaha Super Tenere (non-es)
Offline smalls78
« Reply #18 on: October 10, 2017, 04:14:06 pm »
I have noticed the MadStad bracket doesn't always stay in place.
Offline Terminus
« Reply #19 on: October 10, 2017, 04:32:14 pm »
I don't think I have had that problem for the most part.  I did notice that you have to make sure the screw knobs are set just right in the notches on the bracket.  You can feel them.  if you tighten the knob in between two of the notches it will just vibrate loose.  Hard to explain, so I hope you are following me.
Online Cycledude
« Reply #20 on: October 11, 2017, 05:14:20 pm »
I have the tallest and widest VStream and wow it’s a huge improvement over the tall Yamaha shield I was using.
In the tall position yes the hand guards do slightly bump the windshield but in my opinion not enough to really bother anything.
I’m currently running it in the low position and the hand guards do not hit anything.
But I am very curious how an even wider VStream would work,  if they would ever start making a wider one with bigger cutouts for the handguards I’d most likely give it a try.
« Reply #21 on: October 11, 2017, 05:39:51 pm »
I still have the stock/OE windshield.  I don't really see a difference between all the way up/down.  I ride practically every day, over 40*, but I'll never be an Iron Butt participant.  Since this is Texas, I ride with the windshield all the way down; more airflow.  I have a silverback body type, and have my seat on the low position.  I don't get much helmet turbulence, unless my wife is on the back.  I don't think there is a windshield made to protect from high crosswinds.  And turbulence/dirty air off of other traffic is also hard to eliminate.  I think weight makes more of a difference than a windshield.
Offline holligl
  • Find the road less traveled...
« Reply #22 on: October 12, 2017, 09:55:40 am »
I just changed my style after a long weekend with some longer rides.  My legs were cramping so I changed the seat to the high position and then jacked my Tall Yamaha touring screen from the second position to the highest point.  I found the additional leg room refreshing and the screen actually quieter for me here.  (I'm 6', 32" inseam)  Slightly more through the screen view.  I do find it interesting the amount of bug splatter on the backside of the screen.  I guess they're exploding as they come through the venting under the screen.
2014 BluES
Offline smalls78
« Reply #23 on: October 12, 2017, 11:26:43 am »
I'm 6'1" and I'm riding the same style. I tried the lower seat setting and found my windshield worked better, but I couldn't ride like that with my long a$$ legs!
Last post April 16, 2012, 06:10:34 pm
by norcal rider
Last post July 01, 2012, 11:31:30 am
by Combo
Last post July 23, 2015, 06:04:11 pm
by MIKE R
Last post January 04, 2013, 03:55:43 pm
by joneil
Last post January 16, 2015, 01:53:51 am
by tomatocity
