Author Topic: Flashing cruise light  (Read 1424 times)
Offline gv550
« on: August 30, 2017, 05:19:38 pm »
After 50 weeks and 31k of S10 ownership, I had my first problem with the bike. The cruise light flashes and SET does not engage, sometime right from a standing start, and sometimes it will engage then kick off and begin flashing after riding for a bit.
Since it's under warranty for 2 more weeks I took it to my dealer and they said there was a stored code 90, he cleared the code and it didn't return so they sent me on my way without replacing any parts. It has worked fine now for 2 days, but I'm not convinced it is repaired. The repair attempt is on record so I guess if it fails again it should be covered even if warranty expires.
I'm curious what is the cause of the flashing light? Problems with a switch, or ECU, or wire connection?
Garry
2016 Super Tenere ...fast Yellow....
*Givi engine guards, skid plate and XS308 tank bag.
*Oxford heated grips with Grab-on wrap.
*Yamaha panniers and top box.
*Yamaha tall shield and side deflectors.
*Zumo 395 with TPMS
*Mitas E07 tires
2009 Kawasaki Vulcan Voyager
Offline Gigitt
Re: Flashing cruise light
« Reply #1 on: September 01, 2017, 09:05:41 am »
There are a couple of potential issues that cause the CC o fail.
Main culprit is the Rear break light switch - either dirty or poorly adjusted. Make sure that it is adjusted properly when the pedal is pressed so that the rear brake lights come on. Sometimes your foot touches the pedal can activate the switch which will cause issues.
other issues are the other switches that are used to cancel the CC = rear brake switch, front brake lever switch, clutch lever switch, also throttle position (rolling the throttle negative ie past normal zero position will cancel the CC)
another thing is dirty/faulty ABS sensors. The bike measures speed from the ABS sensors.
Offline gv550
« Reply #2 on: September 01, 2017, 01:04:35 pm »
I understand how an open switch could cause CC to not set, but what causes the flashing cruise light? Intentionally holding a switch open while trying to set CC doesn't cause the flashing, and opening a switch while riding just cancels CC without causing the flashing.
I have cleaned the wheel sensors, and I will remove, clean the switches and check the settings when installing them.
Garry
*Zumo 395 with TPMS
*Mitas E07 tires
« Reply #3 on: September 01, 2017, 01:09:55 pm »
The flashing is how the system informs you that it detects a fault somewhere. When my trailer wires chafed on the rear heel and shorted, my first clue was the flashing cruise light.
Offline gv550
« Reply #4 on: October 07, 2017, 10:15:56 pm »
A month later and my flashing cruise light problem has returned. And again, code 90 is stored.
I Have removed and disassembled the rear brake switch, it wasn't very dirty but I cleaned it and put it back together with dielectric grease, removed the front switch and sprayed contact cleaner through it, and unplugged every fuse and wire connection. None of this work solved the problem, but clearing the code did stop the light from flashing. I'll take it for a ride tomorrow to see if the cruise works.
Garry
*Zumo 395 with TPMS
*Mitas E07 tires
Offline gv550
« Reply #5 on: October 08, 2017, 08:02:14 pm »
I went for a ride today and the cruise worked for a while, actually quite a distance until I did several stops in traffic then the light began flashing. I stopped and cleared the code 90 and continued on, this time paying closer attention to what was happening. Using the front brake only, the light would flash after several applications of the brake. And using the rear brake only, the light would flash after several applications. So, either brake switch causes the code 90. I doubt if both switches are faulty so I'm guessing the problem has to be in the circuit or relay?
Thoughts anyone?
Garry
*Zumo 395 with TPMS
*Mitas E07 tires
Offline gv550
« Reply #6 on: October 08, 2017, 08:25:18 pm »
Another update.... I can duplicate this issue with the bike parked in my garage. Ignition on, (engine not running, wheels not turning) turn on cruise and the light comes on steady, activate either brake several times and the cruise light flashes with code 90 displayed.
Garry
*Zumo 395 with TPMS
*Mitas E07 tires
Offline BigBob
« Reply #7 on: October 09, 2017, 01:32:00 am »
Remember linked brakes. Check rear first. Only thing in common
Member of Mid-Iowa Star #210
2014 Super Tenere ES
2010 Stratoliner Deluxe
Offline gv550
« Reply #8 on: October 09, 2017, 10:57:32 am »
Thanks, I've had the rear brake switch removed and disassembled. It wasn't very dirty but I cleaned it and reassembled with dielectric grease on the contacts, and installed it so the brake light comes on after pressing the pedal at least an inch.
I've also run the onboard diagnostic, step 82 tests all the switches in the cruise cancel circuit and step 83 tests the brake light portion of both switches, and it passed all the tests.
I can duplicate the flashing cruise light problem with the bike parked in my garage, and I believe the linked brake feature comes on only after the bike is rolling.
Garry
*Zumo 395 with TPMS
*Mitas E07 tires
« Reply #9 on: October 09, 2017, 04:02:51 pm »
Can anyone tell us if this test is valid?
I'm thinking: no, because the ABS system has not yet passed it's test (ABS amber remains illuminated until after rolling, and then ABS amber turns off if it's test passes).
Offline gv550
« Reply #10 on: October 11, 2017, 08:56:13 am »
I went for a 400 km ride yesterday and the cruise quit 3 times, all within the first 50 km. Each time I had to park off the road and turn the bike off with the key, then restart and the cruise would work again without clearing the code 90.
I stopped in to report this to my dealer, the warranty has now expired but they failed to fix it when I brought it there under warranty, so the dealer says he is going to discuss it with Yamaha.
It is ironic that the only issue I have with the bike is the cruise, it is major factor in deciding to buy an S10 as I have nerve damage in my right arm and can't hold the throttle much longer than 5 minutes at a time.
Garry
*Zumo 395 with TPMS
*Mitas E07 tires
« Reply #11 on: October 11, 2017, 09:27:53 am »
Dealers generally come back with "first time we heard of . . ." so you might search here for related threads about "cruise control problem" and "code 90" to print and take along.
Offline satdishes
« Reply #12 on: October 22, 2017, 12:23:05 pm »
I'm having same issue with my 2014, I will share when I figure it out. FYI my high and low beams went out shortly after flashing started. I think it's related.
Sent from my P00I using Tapatalk
Offline gv550
« Reply #13 on: October 22, 2017, 04:53:50 pm »
Looking forward to your input, Several of us have recently postd about flashing cruise light. Almost an epidemic...............  :question:
Garry
*Zumo 395 with TPMS
*Mitas E07 tires
« Reply #14 on: October 22, 2017, 08:35:08 pm »
Satdishes:  To be clear, you're telling us that shortly after an issue with cruise control (you do not give any details about the specifics), your main headlights lights went out, and stayed out. Now, you have a code 90 stored in the fault history of your cycle.
Did I understand all of that correctly?
Last post June 20, 2012, 10:08:40 pm
by gbergma1
Last post January 30, 2013, 04:55:34 pm
by markjenn
Last post May 11, 2017, 12:36:20 pm
by RicoChet
Last post June 25, 2016, 07:58:58 am
Last post August 10, 2017, 03:33:54 pm
