Author Topic: installing a 12v USB and Voltage meter  (Read 1826 times)
Offline TimLaw
« on: October 04, 2015, 04:19:53 pm »
After I get a dash infill panel, I'm looking at hooking up a USB, 12v plug and a voltage meter.  I don't want to splice any wires and go directly to the battery.  Can I connect all three leads together and then go to the battery or do I need three separate harnesses to the batt?
It looks something like this....
Offline Brick
Re: installing a 12v USB and Voltage meter
« Reply #1 on: October 04, 2015, 04:35:37 pm »
I would take the USB and the 12V plug through a FZ1 Fuse Block http://www.fuzeblocks.com/ and the voltage meter I think I would go directly to the battery.
Who makes this unit. It looks quality!
YMMV
'14 ES Yamaha Super Tenere'
'99 SV-650
'15 FJ-09
Wanna see where I'm riding?
http://tinyurl.com/3a343vx
www.ridemsta.com
« Reply #2 on: October 05, 2015, 07:40:36 am »
While I have a Fuzeblock on the newest bike and agree that it is great, even a wire to a voltmeter ought to be fused. It would be kinda silly to short the voltmeter wire and lose the bike, simply because an unessential item had no fuse protection.
Answer to the OP, yes, you could use one supply wire to the three devices.
Offline patrickg450
« Reply #3 on: October 05, 2015, 08:04:50 am »
product made in the USA!!!!!
I know who will have my business next time.  I made my own outta stuff I had, had I seen this it would be on my bike.
Good find Checks
2012 Super Owner
every man dies, not every man lives
Offline TimLaw
« Reply #4 on: October 05, 2015, 09:51:59 am »
totally agree with the fuse(s).  I found this on ebay with the jumper wires and fused harness.
Thanks for the comments and help.
Offline camardelle
« Reply #5 on: October 05, 2015, 10:20:29 am »
At Fuzeblocks's w3ebsite ad clicking on the buy button only gets me to an info page.  Where can you purchase these?
2015 Super Tenere ES
Offline Brick
« Reply #6 on: October 05, 2015, 10:29:27 am »
http://www.fuzeblocks.com/  ::022::
'99 SV-650
'15 FJ-09
www.ridemsta.com
Offline camardelle
« Reply #7 on: October 05, 2015, 10:38:16 am »
That's where I was.  LOL  There's a "buy" button but it has no function other than to reload the page that shows the FZ1.  I did manage to locate it on another vendor's website so I'm good to go.  I would prefer to buy it direct so if anyone has any suggestions please feel free.  Thanks!
Offline stormingnorm
« Reply #8 on: October 11, 2017, 05:30:50 pm »
i actually fitted a couple of these units to my boat last year. found several different suppliers and even different versions with different lighting etc.
you can mix n match to suit and I've found they work very well so far
« Reply #9 on: October 11, 2017, 07:23:50 pm »
YMMV
I agree, if you lump the voltmeter in with the other two or connect it to some other shared circuit, my experience is you can get an inaccurate battery voltage reading, in this case, when you place a load on those outlets, voltage read out might be reduced.
« Reply #10 on: October 12, 2017, 12:59:34 am »
I tapped the power from one of the accessory outlet connector, the 3 pin type connector.  (at the battery area) . This way, the Key controls the power on and off.  There is a drop of 0.3V is using a Voltmeter tapped to this circuit.
Offline mebgardner
« Reply #11 on: October 13, 2017, 10:40:47 am »
Wired an Eastern Beaver power block directly to battery, and tapped one of the switched outlets.
Motorcycle electrical systems are notorious for being "flakey", unreliable, and / or underpowered.
The S10 is excellent in it's electrical supply robustness. Not so much in long term harness integrity (switches, connectors, etc).
Any cycle with an oil bath submerged stator, gets a voltmeter on the dash.
2016 ST, Non-ES, Power Commander PCFC, Seat Concepts, Rox 2" Risers w/ OEM lines, Aux: ADVMonster 44W LEDS and Dimmer, HL: NightEye H7 50W LEDs, Eastern Beaver CS3, Givi TN355 crash bars, Skene Designs Photon Blaster LEDs, Knight Design Wide Hunter lowering pegs, Denali SoundBlaster w/ Twisted Throttle horn mount, SW Motech Evo Side Racks, Saddleman X-Jumbo Cruiser Soft Bags, Hepco Becker Rear Rack, Hepco Becker Junior 45 Rear Top Case, MRA X-creen Tour, OEM reg. shield and bracket, OEM side wind deflectors, RideOn Tire additive, 0.55 in. LED eBay Voltmeter, Battery tender. Hit-Air Airbag Vest, Motoport 3/4 Length 3 Layer Jacket with Quad Armor Upgrade, EVS G6 Mesh Armor (summer), Revit 2 Layer Mesh Pants, A* Corozal Boots, Shoei Hornet X2, Garmin Zumo 550 GPS.
Offline RockyDS
« Reply #12 on: October 13, 2017, 07:58:42 pm »
This is my version.  I wired them all together and then to a Centech fuse panel that I already had installed under the seat.  If there's a voltage drop when the 12v or usb outlets are used that's not a problem for me as I know the reason why.  I incorporated a waterproof switch to isolate the panel.  I also switched the usb/volt meter positions due to clearance.
« Last Edit: October 13, 2017, 08:01:52 pm by RockyDS »
Super Ténéré - Yukon 2012 - Ouray 2013 - PCH 2014
Offline Crew Chief
« Reply #13 on: October 15, 2017, 08:18:34 pm »
The fuse issue has been covered well, but I definitely would not go direct to the battery. The voltmeter in particular, but also the LED's in the other devices will draw the battery down eventually. I have used a number of those types of devices. The voltmeter's have been rock solid as have the cigarette lighter type outlets, but I've had poor luck with the USB devices. The ones I'm using now have lasted longer than any of them, but I've had several fail, including mere minutes after the installation.
Mike Brewster
Current:2014 Super Tenere', 2000 DRZ400, 1995 Kawasaki Concours
Previous: 1975 Kawasaki H1, 1982 Yamaha Seca 650, 2001 KLR650
Last post August 03, 2011, 04:25:22 am
by Bundu
Last post December 18, 2011, 11:43:12 pm
by fender5803
Last post December 05, 2012, 07:52:07 pm
by justbob
Last post February 28, 2016, 12:31:55 am
by Shovelhead
Last post June 08, 2017, 03:15:05 pm
by dietDrThunder
