Author Topic: Shifter jammed into vertical position on tour  (Read 865 times)
Offline Mtbjay
  • In love with two-wheeled machines
« on: July 10, 2017, 06:38:16 pm »
I had my first "accident" after eight-years as a returning rider.  I was on tour and fatigued from a long day that included being caught in snow/sleet storm at 7,000 feet for 70 miles when it happened.  A 0 MPH tip-over.  My stubby legs, and a lack of assertiveness while I was attempting a 3-point turn on a narrow forest service road, left me without forward momentum just long enough to stall a tip-over.  The bike sustained barely a scratch, but curiously, the shifter was stuck in a vertical position (12 O'clock), noticed once the bike was upright.  A few attempts to push it back down were unsuccessful.  Then I had the idea to start the bike and pull the clutch before trying again.  It worked and the shifter dropped into place.  Outside of a minor bend in the connecting rod, everything seems right.
What happened?  Should I inspect anything for damage?  Anyone else experience this?  (My boot tip caught the shifter as I attempted to hold the beast from tipping, then had to bail-out to avoid being caught under the machine.)
2012 ST1200Z
OEM heated grips, bags, fog lights; V-Stream Windscreen, Fender Extender
Re: Shifter jammed into vertical position on tour
« Reply #1 on: July 10, 2017, 09:32:07 pm »
I've bent the shifter and bent it back, but vertical? Got photos?
Offline Mtbjay
« Reply #2 on: July 13, 2017, 01:42:59 pm »
Nothing?
2012 ST1200Z
Offline PowersUSA
« Reply #3 on: July 17, 2017, 07:54:26 am »
Had the same thing happen to me this weekend. Same end result, it pushed back through to the normal position and a slightly bent connector rod. I don't know how "safe" it is for the shifter to rotate that far "up", but so far it seems fine.
« Reply #4 on: July 17, 2017, 10:45:55 am »
Two in a few days, huh. I'm hopeful these don't happen in 3's.
« Reply #5 on: July 17, 2017, 12:29:38 pm »
If anyone does happen to have this situation, snap a pic and post it here...
« Reply #6 on: July 17, 2017, 01:45:34 pm »
 ::006::
Offline lynnsox
« Reply #7 on: July 18, 2017, 12:40:15 am »
Here's your third. Exact same thing happened to me Sat morning. Going downhill in first gear , wet grass and a few clay ruts= instant down. Shifter straight up. Put it back in place and rode another 500 miles for the weekend no worse for wear except a slightly bent shift rod. will repair this week. Sorry no pics either!
« Reply #8 on: August 06, 2017, 01:10:56 pm »
I did this to mine several years ago. Low speed drop on the left side resulting in the shifter pointing straight up. I pushed it back forward, and it "snapped" back to the horizontal position. Was able to rebend the shift rod somewhat straight, and rode home. I replaced the rod, not because it wasn't working, but everytime I looked at the bike, it seemed to say to me that I owed it a new one...lol.
That was 40K miles ago, and still going. Tough bike.
Offline msch
« Reply #9 on: August 06, 2017, 07:44:25 pm »
The same thing happen to me on February this year. I pushed back through to the normal position and ended with a bent connector rod. Corrected the bent connector to a slightly bent doing force with my hand. Shifting worked well. At home disassembled the connecting rod, aligned it and installed back.
I believe this is an excellent Yamaha design that avoids broken parts. Did not took pictures.
F. Martin Schneuer
Last post August 21, 2011, 04:08:37 am
by tomatocity
Last post October 13, 2011, 02:20:07 pm
by Twisties
Last post November 30, 2012, 08:12:50 am
by Koinz
Last post February 07, 2015, 10:21:37 pm
by HeliMoto
Last post July 10, 2017, 09:34:48 pm
