Author Topic: Denali Auxiliary Light Mounting Bracket (Twisted Throttle) ?  (Read 9787 times)
Offline spam16v
Re: Denali Auxiliary Light Mounting Bracket (Twisted Throttle) ?
« Reply #30 on: September 12, 2015, 11:05:10 am »
What search criteria did you use on Ebay? I get the PIAA brackets, can't get your style to show.
http://www.yamahasupertenere.com/index.php?topic=17285.0
Offline spam16v
« Reply #31 on: September 12, 2015, 11:06:32 am »
The 6" light bar is eBay, the Duallys are on a Denalli bar
Offline 10éréRider
« Reply #32 on: September 12, 2015, 11:56:25 am »
I didn't use the official Denali mount as they weren't available at the time I was installing these. I don't remember the brand of the mount but I bought them at Dual Sport Plus in Brantford. I like the position of them. They are kept out of harms way in case of the bike falling over (tested and passed!) and they are very sturdy. I thought I would show you my mounting in case you were looking for options.
10éréRider
RD350, RZ350, IT175, FZ750 and Super Tenere (White and Red)
Offline Wobbler
« Reply #33 on: September 12, 2015, 08:55:51 pm »
Hey, if these are the 4" ones, they are really awesome.  I plan to mount them on my bike.  Has anyone heard about mounting them on the forks instead of the bike's body for better direction control?
« Reply #34 on: September 12, 2015, 09:12:14 pm »
I know Clearwater lights offers a bracket for mounting lights at the fender mount bolts.  I got a set of brackets from Jaxon (Tabasco) and mounted mine up on the handlebars.
« Reply #35 on: September 13, 2015, 01:12:29 am »
Gotta remember the forks are vibrating up and down thousands of times per mile, the bigger heavier lights will beat themselves and their mounts to death in short order.
Offline SIXTEEN
« Reply #36 on: July 17, 2017, 11:46:27 am »
So does this Denali Mount work on the Gen 2 Ténérés?  The "instructions" say from '11 - '14, but ZevRilla says '11 - '16.  Would I just need to modify the trim cover on mine?  Or just leave it off?  Hmmmm.
 ::021::
Offline Mellow
    • ST-Owners.com
« Reply #37 on: July 17, 2017, 12:47:33 pm »
 ::021::
Well, mine is a 2014 which is a  Gen 2 so both are right.. lol
I didn't mount the trim cover as I added the 6" light bar there but I don't think you have to do anything to them...
Offline Wobbler
« Reply #38 on: August 27, 2017, 06:51:36 pm »
I've had the Denali Lights for about a year.  The mounts from Twisted Throttle worked great.  At first, the only thing I had a problem with was the alignment.  But once I zero'd in on the position, they were excellent.  I have the option to operate with the switch or I can go through the high beams.  Let there be light!
Offline jeepinoutwest
« Reply #39 on: November 12, 2017, 08:33:10 am »
Sixteen I see your dilemma. The installation instructions clearly show a different bolt pattern than my '17. I have a question into Denali. We'll see if the respond.
2001 Honda Saber - sold
2003 Yamaha FZ1 - sold
2005 Yamaha FZ6 - sold
2007 Yamaha Vstar 1300 - sold
2008 Kawasaki Versys - sold
2009 Yamaha FZ6 - sold
2010 Yamaha Raider - sold
2012 Kawasaki Ninja 1000 - sold
2014 Yamaha FJR - sold
2015 Yamaha FJ-09 - lemon back to dealer
2016 Yamaha FJ -09 - sold
2017 Yamaha Super Tenere ES
Offline abong
« Reply #40 on: December 02, 2017, 03:17:20 am »
Let there be light!
« Reply #41 on: December 16, 2017, 12:46:17 am »
Denali seems to be the house brand of Twisted Throttle. They got back to me and with half confidence told me that the bracket should work on my '17. I'll order it up soon. Can anyone recommend the most inexpensive place to buy the Rigid D2s (202113) from? Also on this bike I can wire everything right up to the unused 3 prong unused auxiliary plug, correct? I would only need to use 2 wires from it, ground and switched live, correct? No need to go back to the battery for anything, right? Tap the pink wire for the high beam trigger to relay? Thanks guys!
« Reply #42 on: December 16, 2017, 03:06:49 pm »
If you're using the high beam to trigger the lights, you would use the unswitched hot wire in the 3-prong connector, rather than the switched line (which is designed for the relay trigger in the OEM fog light kit).
« Reply #43 on: December 16, 2017, 07:33:39 pm »
Thanks AVGeek, you save me some grief and aggravation. Much obliged!
Last post July 06, 2011, 08:43:40 am
by Hoosier919
Last post August 03, 2012, 06:04:15 am
by hANNAbONE
Last post December 18, 2013, 11:38:06 pm
by snakebitten
Last post September 30, 2014, 02:26:59 pm
by mrpete64
Last post November 21, 2017, 11:03:48 am
by Bear
