Author Topic: Later clutch basket,does it really make a difference?  (Read 2388 times)
Offline Ironhand
Re: Later clutch basket,does it really make a difference?
« Reply #15 on: June 12, 2017, 01:48:21 pm »
Like Eric, I wasn't particularly sensitive to the 3K vibrations as reported here frequently.  However, I did eventually swap out the basket and did a TB sync, and the before and after difference was easily noticed.  Definitely a recommended mod.
Having come off a VStrom 1000 which was known to have a fairly pronounced "chudder" issue, I was dismayed to find that the ST had the same problem.  The 2014 basket was a huge improvement.
2015 Ural Gear Up
2012 Super Tenere
2008 XR650L
2003 FZ1
“The two most important days in your life are the day you are born and the day you find out why.”  ― Mark Twain
Offline barkingllizard
    • @theparty@theendoftheworld
« Reply #16 on: June 13, 2017, 09:05:12 pm »
yes.....
comments with substance will be chastised by soulless pub riders lacking intelligence and imagination...
while calling out princess trolls will be met with the monomaniacal pruning shears of triggered snowflake censorship.....
Offline jbrown
« Reply #17 on: June 14, 2017, 04:01:35 pm »
it depends on how bad your original basket is.
I replaced the basket on my low mileage 2012 with the 2014 part, and there was only the slightest change.
A little bit less shake in the 3000 to 3500 rpm range,  and a little bit *more buzz* above 4500 rpm.
Offline fraserdog
« Reply #18 on: June 14, 2017, 04:16:45 pm »
i feel perhaps i ought to try and get a ride on a 14 onward model and do a comparison before i part with my money.
Offline AlsoRan
« Reply #19 on: June 14, 2017, 04:31:11 pm »
I purchased a '14 clutch basket on the first day they became available and happend to get the only one in-stock the time. I figured at the price I would "try it" as sort of a guniea pig and if it didn't work I could go back. Well it made all the difference, solved the problem and made the bike a joy to ride. I tried other modes to fix the vibration and they helped but the source of the real problem was the basket. So I've been pleased with the change and several thousand miles later with no issues, my thought is that I would buy the basket at the higher price no doubt. Plus it's less money than buying a new Super T!
Offline RonH
« Reply #20 on: June 14, 2017, 09:48:46 pm »
I replaced mine on the 2012 for the $27 price and it did make a nice improvement, but only in the 3200RPM zone more or less. For $300-$400 I would not do it.
2017 Super Tenere 1200ES, 2008 Honda GL1800 Goldwing
Offline Arkyrider
« Reply #21 on: June 18, 2017, 04:13:20 pm »
I replaced mine on my 2013 for the $32 price.  It did make a slight improvement but not as much as I had hoped for.  If I had to pay $300+ I would probably not do it.
Offline snakebitten
« Reply #22 on: June 18, 2017, 04:47:54 pm »
Changed mine shortly after it became all the rage.
Honestly, I wasn't sure what the issue it reportedly resolved actually was. Or, if my bike suffered from the malady.
Turned out, much like the ecu reflash, the change was quite dramatic and a significant improvement.
Combine those 2 upgrades with a well sorted suspension, it's made it difficult to convince myself of upgrading to a gen2 Tenere.
I suspect I will at some point. And then be admonishing myself for not doing it earlier. :)
XT1200Z  TBDBITW  (The Biggest Dirt Bike in The World)
KTM 500 EXC              Dirtiest Street Bike In The World
KTM 950 SE           (The Substitute for the XT700Z that's coming)
« Reply #23 on: June 18, 2017, 07:41:48 pm »
I was in the same boat. Didn't really detect any vibe. I went after the extra mass. What was it, 12oz? 10? It made a huge difference in the engine's manners for me. Very pleased. I did though wind up with an almost Royal Star volume gear whine. I don't really hear that any more, it mellowed out with a little wear. The RS4 might have done something there though. ::26::
Offline DonB
« Reply #24 on: June 19, 2017, 08:22:29 pm »
I did mine after 6000 miles on a 2012.  Big difference.  The 3800 rpm vibe gone but also the walnut in a can rattle is also gone.  Quiet idle!
Offline fraserdog
« Reply #25 on: June 20, 2017, 02:35:15 am »
The general consensus of opinion is to get mine changed then if i want to get rid of the vibes,i've just got to find the cheapest supplier i can get one from now.
Offline 911guy
« Reply #26 on: August 08, 2017, 11:15:37 pm »
I performed this upgrade spending close to $300.00. I would do it again in a hearbeat. My bike is so smooth in the 3-4k range now it is unbelievable. There are multiple springs that flop aound on the old basket. The 2014 basket is totally different. I got my parts from partszilla. You need to be sure to get the gasket and lock nut when you do the job.  ::012::
Offline ~TABASCO~
  • RIDE ON ADV is what I do !
« Reply #27 on: August 09, 2017, 01:06:12 am »
Yes, 100%
Lowering Links & Rising Links shipping now !
Shipping HEIDENAU'S... In stock
www.rideonadv.com
2012 Super Tenere - 1"bar riser - motoX grips - ECUnleashed flash - Barnett clutch pressure plate - UNI filter - Air box mod - Akrapovic custom muffler - Arrow headers - PCV&AT - Ohlins suspension front & rear - Trailtech Voyager - Steel braded lines on everything - Ride On skid plate - Carbon fork guards - rear disc gard - rear res guard - WC turn signals - WC headlight guard - ADV tires - WC/ride on graphics - sync TB - Baja Squadrons & S2 - custom dash LED's - Custom light harness - Ride On custom light switch - Keyless gas cap
Offline cyclemike4
« Reply #28 on: August 09, 2017, 08:20:16 am »
Here is my experience with the clutch basket change. I had to do a valve check and wanted to change the timing chain tensioner on my 2012 so I thought what the heck I will change the clutch basket too and see what everybody is talking about. Wow! wish I had done that right after I got the bike. I did see one member mention he thought it throttled better. Mine definitely does. I have been riding around what I thought was a fueling issues but it was the springs compressing then rebounding in the dampening system of the original clutch basket being counter productive to the drive of the motor. Not sure if that wording makes any sense to you all but all I know is when I drive out of corners at low rpm's or take off from dead stops that crazy pull choke pull feeling is gone. Now it is pull the whole time as I roll the throttle on. Wish I had done this 40,000 miles ago! Not to mention the clutch is quieter now. The motor is still noisy though. ha ha.
Offline jbrown
« Reply #29 on: August 09, 2017, 10:45:01 am »
There clearly must be a large range in quality of the original basket.  Am I the only one that could barely tell any difference?
Last post August 29, 2014, 06:17:56 pm
by Koinz
Last post July 04, 2014, 05:19:25 pm
by Koinz
Last post November 08, 2014, 08:37:23 pm
by Hungry Tiger
Last post September 18, 2015, 07:14:23 pm
by Mikel
Last post June 11, 2017, 10:40:45 am
