Author Topic: Alternatives to the Altrider Sidestand Foot?  (Read 1092 times)
Offline cavenger
« on: June 02, 2017, 08:06:39 am »
Are there any alternatives to the Altrider sidestand foot? Its like $70. Seems a bit pricey.
2014 (Non-ES) Super Tenere
Offline worncog
  • Live a life worth living.
Re: Alternatives to the Altrider Sidestand Foot?
« Reply #1 on: June 02, 2017, 08:43:15 am »
I went with the Touratech sidestand foot. Not much less, but it was $59 and is well designed. I was surprised when I received it and their were quite a few pieces to the design. Assembled without a hitch. Worked great on my last two adventures with not a second thought when placing it in soft sand and various terra firma.
14 Super Tenere, 06 Concours, 74 R75/6 Hack, 72 XS650, 02 TTR250
Offline Spider
« Reply #2 on: June 02, 2017, 08:45:55 am »
Well, a beer can works.  And it comes with a prize inside!  ;)
2012 Super Tenere
2016 Tiger 800 XRT
Online Dogdaze
« Reply #3 on: June 02, 2017, 08:49:24 am »
I think Jaxon makes something that is item of beauty, or do what I did, sliced a hockey puck in half to reduced thickness and tapped the foot of the sidestand and attached said puck to the sidestand with recessed screws.
Offline RicoChet
« Reply #4 on: June 02, 2017, 09:19:12 am »
 ::020::
This is actually not a terrible Idea. I used to find a flat rock or piece of wood when I arrived at a destination but if you squash a can really good and just toss it into a bag or something it can be quite useful!
However with that being said, I WISH I could of only payed $70 for the foot, up here in Crazy Canucka land it was something like $130 CAD so ... stop complaining :)
Current Bike: 2016 Yamaha Super Tenere ES & 2012 Triumph Rocket III Roadster
« Reply #5 on: June 02, 2017, 09:25:37 am »
I really like the AltRider side stand plate.  It's a design that doesn't interfere with the swing of the stand, but gives you the larger foot for soft ground.
That said, with the aluminum foot of your side stand, there are still alternatives in the do it yourself category.  It will mean drilling into the stand so you can bolt something on.  Find a plastics shop near you and ask for a piece of UHMW that is large enough for what you want.  Typically they will give you scraps or sell you a small piece for a few dollars.  It comes in white and black and is a fiber reinforced plastic that is very resistant to cracking and has self lubrication properties.  It's commonly used for marine applications, as well as a common off road skid plate material among DIY guys.  A 3/4" thick piece would work well, though thinner or thicker will be ok too, depending on how much rise you want/can tolerate.  I don't think I'd go thinner than 3/8" just to keep it rigid.  The same could be done with other rigid materials like aluminum or even wood.  Shape the piece so it looks pleasing to you, spray some paint on it so it doesn't look bad, (or leave it bare in the case of the UHMW), and off you go.
The simple method as Dogdaze suggested would require a drill, or drill and tap threads in the bottom of the foot for the bolt(s) and don't forget the Loctite.
Offline AVGeek
« Reply #6 on: June 02, 2017, 11:26:09 am »
I wound up with a bunch of these:
Tie a string through the hole, and you can easily retrieve it while seated on the bike.
IBA# 54462
« Reply #7 on: June 02, 2017, 11:32:26 am »
Most motorcycle dealers will give away the pads that AvGeek showed. I keep one in my pocket.
For $1.41 at most hardware stores, you can get a metal electric outlet cover to keep in your jacket or tank bag. Tie a string to it and it's easier to pick up.
When needing something quick, I'll occasionally just drop a glove and put the side stand on that.
Offline copb8
« Reply #8 on: June 02, 2017, 01:14:35 pm »
I have Jaxon's. Simple to install and decent looking. I did notice it's the first thing to touch down when leaning hard into a left-hander. So now I have a customized shape  ;D
Bart
2013 Super Tenere
2016 KTM 690 Enduro R
Offline SilverBullet
« Reply #9 on: June 03, 2017, 01:40:12 pm »
Except if you drink Guinness. The prize inside prevents the can from smashing flat so it doesn't work under your kickstand. Lol
_
2013 Yamaha Super Tenere
2011 Husqvarna TE630
2004 Suzuki DL650 V-Strom
2002 KTM 300 EXC
Offline whisperquiet
« Reply #10 on: June 08, 2017, 08:00:21 am »
I made a 2014 side stand "big foot" by copying the size of the Touratech on my 2013 S10........ugly, but works fine using plastic cutting board material.  Cost $10.00 to buy a new cutting board.
« Last Edit: June 08, 2017, 08:02:04 am by whisperquiet »
2002 KTM 300 EXC
Offline cavenger
« Reply #12 on: June 09, 2017, 05:54:24 am »
Offline cavenger
« Reply #13 on: June 17, 2017, 08:27:45 pm »
ADV Motorrad sells a nice looking DSBP one for $36.99
https://www.advmotorrad.com/shop-by-motorcycle/yamaha/xt1200z-super-tenere/dsbp-side-stand-enlarger-xt1200z-super-tenere?sort=p.price&order=ASC&limit=100
A++ on this side stand foot from ADV Motorrad. I think it looks good and it really makes a huge difference for making the bike feel stable on the side stand especially fully loaded. Thanks again!
Last post October 18, 2012, 07:23:27 pm
by CapsLock
Last post February 25, 2013, 02:51:11 pm
by terrysig
Last post June 13, 2013, 10:35:05 pm
Last post July 08, 2013, 11:16:18 pm
by eastwa
Last post December 26, 2015, 11:26:31 am
by Tyke
