Author Topic: Clutch line leak  (Read 138 times)
Offline nelly5
Clutch line leak
« on: April 13, 2018, 12:16:50 pm »
Hello,
I’ve installed the extended clutch and brake lines from Jaxon. The brake has been no issue, but my clutch is giving me trouble. I believe all is installed correctly, but when I pull the lever and get resistance, there is a leak at the banjo fitting (from the right washer area). I’ve tightened to 22 ft lbs.
Does anyone have any ideas?
Thank you.
  • 2012 S10
Re: Clutch line leak
« Reply #1 on: April 13, 2018, 12:23:23 pm »
I've seen new bikes on showroom floor leaking. Damaged the paint too.
Just reinstall with new washers.
Marriage:
My wife said it was like a deck of cards.
At the start, all you need is 2 hearts and a diamond....
Later, you want a club and a spade.
« Reply #2 on: April 13, 2018, 12:43:16 pm »
The washer on the reservoir side doesn't look centered.
Replace the washers and try again??
« Reply #3 on: April 13, 2018, 01:49:58 pm »
Even the right washer??? Seems a little on the small side if that was the replacement..........
Offline BWC
« Reply #4 on: April 13, 2018, 05:06:16 pm »
Hello,
Thank you
We both seem to have similar pictures.🙁
 I had a leak on the brake side from the extended lines I got from Jaxon. After trying new washers etc. it turned out the line was not manufactured properly and was leaking from where the line is joined to the fitting.  Looks like his supplier has a quality control issue occasionally. You can take a bit of electrical tape to hold the clutch lever down and see if you can confirm if yours is leaking from that joint or from the bolt/ banjo fitting and two sealing washers.  In my case I got ahold of Jaxon and he sent a replacement without issue.
Offline nelly5
« Reply #5 on: April 13, 2018, 05:30:12 pm »
I’ll have to take a closer look. Thank you for the information.
