Author Topic: Turn signals working erratically after riding in a light rain!  (Read 469 times)
Offline CY
« on: February 12, 2018, 08:55:58 am »
   Riding along after a light rain I noticed that the R/S signal was on!  I kept trying to cancel but it wouldn't stop.  After some time they started to work normally.
The other day I washed the bike and after sitting for about 10 minutes the R/S signal was on as before!  Has anyone had this happen to them? & How to fix it?
2015 base Tenere, 5k miles. No accessaries added.
Offline Ramseybella
Re: Turn signals working erratically after riding in a light rain!
« Reply #1 on: February 12, 2018, 10:57:20 am »
Sounds like water is getting into something and making a connection. May be your TS switch or wires exposed getting wet.
Did you spray your handlebars, hand guards or anything up top?
"Technology applied for the sake of those who wish to escape it"
Offline CY
« Reply #2 on: February 12, 2018, 11:19:56 am »
   Yes I agree, water is getting in to the electrical contacts.  I am going to mist the L/S of the bar to see if I can duplicate the problem.  If this is a unique problem, I would think that it would be covered under YES.  I can't believe this UNSAFE condition would be normal but others may have had the same problem.
Offline Madhatter
« Reply #3 on: February 14, 2018, 07:09:43 pm »
I'm betting TS switch , it is exposed to the elements.... try covering the switch with a plastic bag then spray water see what happens... then you will know....
Offline Madhatter
« Reply #4 on: February 14, 2018, 07:12:14 pm »
like anything else switches etc. do fail ,wear out ..... things happen. I replaced the brake switch on the handle bar , just failed.
Offline CY
« Reply #5 on: February 15, 2018, 06:40:23 am »
  Thank's for the reply.  I will try covering the switch to verify the problem.
« Reply #6 on: February 15, 2018, 03:15:21 pm »
Two screws to remove the switch cluster. Shoot it with contact cleaner. Done in less time than taking to the dealer.
Offline Ramseybella
« Reply #7 on: February 16, 2018, 11:51:51 am »
That works but if it's caused by water getting into it this will not fix it from getting in again.
My cheap LED switch does this after a few thousand miles and i just hit it with a shot of cleaner and then electrical contact lube.
Maybe a little dielectric grease while you have it open and inspect for traces of a leak, traces that show some sort of connection within the switch.
But lets see if it's the switch first.. :-\
I agree isolate the switch with a plastic bag first then spay down the bike, take it for a spin.
If that's not it give it another blast with the bag off and see if that is the culprit.
Offline CY
« Reply #8 on: February 17, 2018, 06:43:08 am »
  Thank's for the input.  This is my project this weekend.  1- Cover L/S of the bar & wash the bike to see what happens.  2- Mist the L/S bar.   3- Open switch & evaluate.   4- Post the results!
Offline stutrump
« Reply #9 on: February 20, 2018, 05:50:19 am »
Any results??
Offline CY
« Reply #10 on: February 20, 2018, 05:01:22 pm »
   Well, after soaking my darlin both Saturday & Sunday, I have not been able to duplicate the problem!  This anomaly must must be one of those things like, UFO's!
I don't think I was hallucinating but I was on medication at the time.LOL  If this does happen again,I will disassemble the T/S switch for evaluation and post the results.
Offline Ramseybella
« Reply #11 on: February 20, 2018, 08:16:21 pm »
 >:( Gremlins.. Time for the bell.. :D
Offline stutrump
« Reply #12 on: February 21, 2018, 05:12:03 am »
Your bike has obviouslyhad it's day.
I'll give you $100 for it ::003::
Offline CY
« Reply #13 on: February 21, 2018, 06:44:09 am »
   I just realized that we are close to the BERMUDA TRIANGLE!
Last post February 03, 2015, 08:12:16 pm
by Don in Lodi
Last post March 17, 2012, 08:25:04 pm
by SpeedStar
Last post November 08, 2015, 09:47:25 pm
by Ben58
Last post February 24, 2017, 09:14:25 am
by mcbrien
Last post February 12, 2018, 01:25:00 pm
