Author Topic: Gen I Windshield on Gen II  (Read 273 times)
Offline terrysig
« on: September 05, 2017, 12:32:47 pm »
Looking to the collective wisdom.
Smashed my holdover bought 2013 (to get the white) into a deer totaling it.
I really liked my Wunderlich bracket with the Yami touring windscreen. Freaking perfect for me.
Immediately took off the crazy heavy and not functional bracket on my new Tenere. Although I like the new windshield I would never use the cross bar and the range of motion did not cut it for me.
I saved my old Wunderlich bracket and darned if it doesn't fit. So I put on my Gen I OEM windshield and it also fit fine.
Before I invest in the Yami touring windscreen and the little black hole covers has anyone gone with this setup?
I know one thing the front end looks much cleaner without the funky bracket.
Thanks!
Offline eemsreno
Re: Gen I Windshield on Gen II
« Reply #1 on: September 05, 2017, 01:13:10 pm »
I also ditched the bracket and ended up with the same shield that I've always used on my 12.
Offline terrysig
« Reply #2 on: September 05, 2017, 01:39:28 pm »
Thanks. I thought as much but wanted to see what folks were doing.
Cheers!
Offline Nissbird
« Reply #3 on: September 05, 2017, 02:38:25 pm »
I replaced the bracket and screen from my 16 ST with the GIVI Airflow from my 13 ST (plus some custom spacers).
Offline terrysig
« Reply #4 on: September 05, 2017, 02:50:01 pm »
So the Givi that fit the 2013 was not an exact fit once you removed the bracket.
I guess that's what I was getting at. The windshield stanchions look exactly the same. The only addition is the black plastic "wings" piece. I was wondering if it gets in the way. It does not with my Wunderlich windshield adjuster in the highest position with the Gen I stock screen. Before I dump money into a touring (taller) screen I wanted to make sure it would fit.
Offline MIKE R
« Reply #5 on: September 12, 2017, 06:37:26 pm »
Exactly what I did!
It's not where you go that counts, it's how you get there.
« Reply #6 on: September 12, 2017, 07:41:18 pm »
I have my '12 windscreen on my '15.  The Gen II dash is different and has the cord in a different spot to the front of the bike.  Because of that, the plastic center part that covers that area under the screen is different.  When I went to mount my Gen I screen, it hit that center black plastic panel.  I ordered the Gen I part, dremeled a tiny area for the cord to clear, and it's a direct fit after that.  That also allows the use of the Gen I side wind deflectors.
The Gen I black plastic center cover is only $6 or so.  The main center piece is the same on both Gens.  This is why the windscreen on the Gen II sucks.  The adjuster bracket is just slapped onto the Gen I part, so the screen is too far forward, causing turbulence at the rider in many cases.  I was happy with my Gen I windscreen/side wind deflector combo.  I'm happy again with the same set up on my Gen II.  FWIW, my bike was bought used with a MaddStadd adjuster, not the OEM one.  I did not care for it, though many do.  I've never had the OEM adjuster to try.
Last post November 21, 2010, 07:54:40 pm
by HoebSTer
Last post February 06, 2014, 12:45:24 am
by Mzee
Last post May 26, 2015, 12:23:48 pm
by RoboCop
Last post August 26, 2016, 10:03:13 am
by ColoRider
Last post January 27, 2017, 08:48:59 am
