Author Topic: Suspension adjustment  (Read 31860 times)
Offline Don T
    • Bike-addict
Re: Suspension adjustment
« Reply #105 on: November 15, 2016, 08:41:46 am »
Thank you Bushyar15 for sharing your thoughts and experience with dialing in the suspension!
After little over a years ownership of my S10, I was much in the same situation as the one you described in the first post - I just couldn't figure out how to set up the suspension of the S10 to my liking.
I tried the adjustments you suggested. It improved things considerably and after a few further adjustments (a bit less preload as I'm lighter then you) the suspension now works impressively well and much better than I had imagined it could.
Cheers
Tonny
Life is an adventure!
XT1200Z '15
Offline Hemitruckin@msn.com
« Reply #106 on: April 12, 2017, 12:21:38 pm »
Just did the suspension settings recommended here, fork preload was a big change, forks c/r were I think spot on. Shock preload takes it to almost exactly one line off full hard. Thanks again for the settings can't wait to try them out.
Mike
89 KX250, 87 KX250, 1980 Yamaha TT250's, 80 IT125
« Reply #107 on: April 12, 2017, 11:29:55 pm »
Sure am glad I have an ES.  Don't even have to get off the bike to adjust.   ::26::
Offline jeepinoutwest
« Reply #108 on: September 11, 2017, 03:22:11 pm »
Hi Guys, so I recently bought an ES version. Is there a conversion chart to explain how to set up an ES bike? I'm about 200lbs with gear and typically have 20lbs of luggage. Is there a proper setting for on road, then a different set up for off road? Sorry for the lack of knowledge if this is a really stupid question.
2001 Honda Saber - sold
2003 Yamaha FZ1 - sold
2005 Yamaha FZ6 - sold
2007 Yamaha Vstar 1300 - sold
2008 Kawasaki Versys - sold
2009 Yamaha FZ6 - sold
2010 Yamaha Raider - sold
2012 Kawasaki Ninja 1000 - sold
2014 Yamaha FJR - sold
2015 Yamaha FJ-09 - lemon back to dealer
2016 Yamaha FJ -09 - sold
2017 Yamaha Super Tenere ES
« Reply #109 on: September 11, 2017, 06:49:31 pm »
The book shows 450lb TOTAL cargo limit, including rider(s).  "I" would think that "you" could get away with one helmet, and luggage when appropriate.  I am thinking 200lbs per helmet, which would allow 50lbs for luggage.  Adjust as needed.  Just try different settings, and find which works best.  I weigh 310ish, and use two helmets.  Rebound dampening is set to soft/-3.  When loaded to max, my rebound is set to soft/hard/+3, depending on road surface.  It's all subjective....have fun finding your sweet spot.  ::001::
Last post November 06, 2011, 07:33:29 am
by Tenerator12
Last post September 13, 2011, 01:20:04 pm
by dcstrom
Last post September 08, 2014, 06:23:57 pm
by VAT
Last post June 13, 2016, 07:41:57 am
by Rodge
Last post January 13, 2017, 10:46:45 am
by klingklang
