Author Topic: Airscrew Adjustment to fix off-idle stumble and Throttle Body Sync - w/ pigtails  (Read 177907 times)
Offline snakebitten
I would apologize for derailing this thread, but it would be disingenuous since I have done it SO many times that nobody would believe me.
So first...........
I don't know how often you should sync your throttle bodies. But more than once a new sync resulted in an unexpected  substantial improvement.
Drives me nuts that I didn't sense the gradual degradation.
Blitz, such a nice thing to say. It's all down hill from now though. Too much pressure. :)
Yes, I wear a helmet. In fact, I dress to crash! ATGATT.
Since you enjoyed.........so, My youngest son is a country sheriff deputy. My daughter has pleaded with her little brother to "do something about it James. Give him a ticket or something. That has to be against some law"
I look at her. Then look up at him. (He's a BIG Boy) He hesitates and asks "dad, that thing does have a license plate right?"
I nod with the biggest grin and say "yep! and I have insurance on it too officer. wanna see it?"
Ain't life grand?
« Last Edit: March 13, 2017, 09:46:22 pm by snakebitten »
XT1200Z  TBDBITW  (The Biggest Dirt Bike in The World)
KTM 500 EXC              Dirtiest Street Bike In The World
KTM 950 SE           (The Substitute for the XT700Z that's coming)
Offline blitz11
Life IS grand, and you make it better with every post.  It's good to have THE MAN (and your son) on your side.
You've raised a fine  family, AND inspired me to double check my carb synch.  I bought a new motion pro tool for my daughter's 1982 suzuki GS650 ($200 craigslist find) a few months back, so i'll use it on the super 10 this weekend.
Thanks for brightening my day.
Offline VRODE
  • Easy Does It
So first...........
Ain't life grand?
Thanks for the sync info!
Being at an age to give your grown kids grief is sweet revenge! Life can be sweet!
2016 ES "Godzilla"
All -
Please use the following sticky for TBS on the Gen2 bikes:
http://www.yamahasupertenere.com/index.php?topic=17494.msg321110#msg321110
If and when I get a chance, I'll try to move the Gen2 posts from this thread to that one.
Thanks!
Offline big dave
 A bit of help please.
I did the air screw adjustment and throttle sync last week and was over the moon with the results.
I set out on a 450mile up to the Scottish borders three days since and it was running perfectly, however over the three days it has started to stutter again and has deteriorated to the point where it now stalls at junctions.
Any ideas, can someone point me in the right direction?
Yamaha XT1200z, Beta 4t trials, Yamaha TDM900, Kawasaki KLX300, Yamaha TDM 850 project
I DON'T DO EXERCISE - if God had wanted me to bend over he would have put cake on the floor
The caps which plug the throttle body ports can crack or get loose. The description seems to fit so I'd start there.
Offline big dave
My first thoughts, but a quick look under the tank on my return home and both look well.
Do the air screws ever move, unlikely I know but I want to eliminate things I may have caused by last week's adjustments
I've never seen the air screws move on their own.
Since the problem started and got worse over a course of days, from what was an acceptable running cycle to begin with (I think that's true, but you don't state it), it's something you did to change it.
It reads like you've got a vacuum leak now. Find That. Look at the things you've touched.
How's the idle speed? Check the left side TB cap. Could be cracked. If the gas tank vent hoses got pinched it will cause the fuel to struggle past the pump.
Offline Xt1200zsupertenere
Read all 34 pages  ::008::
I am about to do TBC ... have got more engine wibes and ingreased fuelconsument  ::007::
Have ECU unleash and ARROW headers. ...
yamaha workshop Done all service Sins new ( 2011 , bought it " new " 2013 and
Now run it 4 years 24 000 Miles )
Dont know if workshop Done the TBC  ::) ::)
The 3/4 airscrew , it is sopose to be Done on europé modell ? ( mine is )
Does is get RICHER or LEANER air / fuelrailen mix by this mod ?
Already have +3 in CO settings
Hello ,I am writing from Italy and I apologize for my english.I would like to ask you ,when you have syncronized the trottle body,have you cheked the levels of depression with a good instrument?Because the service manual says that the levels could be between 26,5 and 29,5 cm hg and after having unscrewed of 270° what are the values? Then I inform you that when the bike have runned for 20000 km you need to clean the throttle body before make alignment . Regards from Italy
About 27,0 on mine after 3/4 turn on right screw on MINE
Because we Europeans told everyone so.
Not mine ! ( Sweden ) ... right screw aout 1/2 turn , left ( WHITE paint ) all closed ...
Should work fine I would think.  I have not played with the settings on the ST yet, but my Morgan carbtune seemed to work fine on the DL1000.
Works great ... i usel it yesterday ... worked perfekt ( as long you have read Manuel and put in the clear plastic in Tubes )
Offline RonH
From what I've gathered, the standard is fully seated, then the other screw is turned out to sync.
2017 Super Tenere 1200ES, 2008 Honda GL1800 Goldwing
Last post July 13, 2015, 10:11:52 am
by Ron14S10
Last post January 10, 2018, 01:23:22 pm
by mebgardner
Last post November 15, 2015, 09:29:21 am
by regulator
Last post March 18, 2018, 08:33:43 am
Last post March 23, 2018, 06:00:34 pm
by Wheelin
