Author Topic: Throttle body sync for 2015 model  (Read 5517 times)
Offline Riteris
TB sync on a 2015
« Reply #15 on: August 12, 2017, 11:15:16 am »
Hi all,
I know that there are dozens of pages here about synchronizing throttle bodies. Unfortunately, those threads have become muddled with information about both Generation one and Generation two bikes, as well as other chatter.
I have read conflicting information about how much to turn out the throttle screws on a Gen 2 bike.
Could we get some guidance from those with experience:
1) Should the throttle body screws on a Generation 2 US bike be turned out 270 degrees or is it something different?
2) Is this something that SHOULD be done on a Generation 2 bike?
THANK YOU!
Cheers,
Chris
Cheers,
Chris
Re: Throttle body sync for 2015 model
« Reply #16 on: August 12, 2017, 11:48:01 am »
Merged identical topics.
As I answered Riteris on ADV:
3/4 will work for the Gen2 but there's a different point where it's smoothest. It's discussed, starting with Post 447 in this thread:
http://www.yamahasupertenere.com/index.php?topic=1973.435
Bottom line was that ride34fun found 1/4 turn worked better then more of us found less as well. Somewhere between 1/8 to 1/2 turn is the sweet spot. For example, see Post #11 here:http://www.yamahasupertenere.com/index.php?topic=17494.msg260937#msg260937
« Reply #17 on: August 15, 2017, 11:38:33 am »
Remember that you want hoses of equal length to your Carbmate/manometer/etc, which is why the extension for the other side.
I closely read the "other" (now 34 page) thread, and could not find reference to what you're referring to in this quote.
I see the various pictures of the "T" setup, OK no problems there for me.
I read various posts suggesting 1/8" rubber "windshield wiper" hose, or 1/8" plastic hose, or 5/32" hose, OK I can sort that out (I'll use your suggestion, and find the 1/8" variety).
Various posts suggest checking the clear plastic "nipples" under the airbox, looking for water and / or oil, and clean them out if you find it, OK good can do.
Various posts suggest to replace the OEM rubber nipple vacuum caps on the TB's, because they wear out and then leak, OK good, I can check that too.
Various posts suggest not laving the "T" setup in place between services, because it could be a source of vacuum leak, OK good tip.
The thing that eludes me is, what length hoses to use, and where, so to make "...hoses of equal length" to the manometer?
I could not find that info.
Thanks!
« Reply #18 on: August 15, 2017, 01:24:18 pm »
Just try to be as equal as you can for length between the throttle bodies to the two sides of whatever you are using to measure.
The left throttle body requires a T, which adds a bit of length on it's own. Some people's definition for "a bit of length" can be a lot.
« Reply #19 on: August 15, 2017, 02:17:12 pm »
OK, understood.
Here's what I'll do then. Since I don't know if the left TB OEM hose length is a critical length, I'll measure it. Then, I'll set it aside for re-installation after test complete.
Using that length measure, I'll deduct the "T" length from it (installed length), and then I'll cut a bit of 1/8" hose to match that final length.
Then, cut it in half, insert the "T", and re-measure. It should be the same length as the OEM bit.
OK, then measure and cut hose bits to the manometer such that all lengths of it are equal *to the TB tip".  That could be important.
Said another way, each manometer leg will be of equal length to the TB connection point.  On the left side, that includes the "T" arm and the bit of hose to the left TB. On the right, it's the length of connection direct to the right TB.
That should do it :)
I'll post up later what I measure.
« Reply #20 on: August 16, 2017, 07:01:46 am »
Manometer tubes design to which I had made and sync'ed more than 10 times.
Bills of material:
1. 4mm ID clear tubes (aquarium shop sells them) - at least 8 feet.
2. T joint 4mm.
3. Wooden beam or plastic pipe pole at least 2.5' long
4. Cable ties.
5. Oil - ATF is red and is good for viewing.
Assembly
1.  Cut out the tube of about 1.5" to 2" and attach it to the T joint.
2. Remaining tube, find the half way point.  Mark it.
3. Place the tube so that it forms a "U" shape and with 2.5 feet on both sides, cable tie to the Pole/Beam.  Create a vertically positioned tube.  The halfway Mark should be right at the bottom of the pole, at the lowest point of the "U".
4. Fill in with ATF so that both sides are about 12 inches level height.
5. Now u have 2 free open ends of the tube.  One end, connect to the T joint.  This end goes to the Left TB.  The other end goes to the Right TB.
Sync'ing.  (I remember clearly as I just did the Sync on 10 Super Tenere's that visited me last weekend).
1. Check the air screws for a paint mark.  The painted screw is the reference screw and is fully closed in.  I have seen UK, US, Japan, Aussie specs S10 and they can be on either side.  Confirm that the screw is fully closed in.  Position the manometer at the opposite side of the reference screw because you will need visual of the levels as you adjust the other screw.
2. Connect the manometer to the TB.  For Left Side TB, remove the MAP sensor black hose, then connect the black hose to the T joint, while the clear hose connects to the barb.  Connect the clear hose on the other TB.
2. Start and warm the bike to 80 C.
3. Open up the reference screw 3/4 turn or in my case, 1/2 turn.  You can do this as the temperature rises.
4. Watch the levels on the 2 sides.  They maybe inches off from each other.  As the temp approaches 80C, the difference in level will stabilie.  Adjust the other screw until the levels are equal.
5. Remove hoses, and replace back the MAP sensor hose and rubber cap.
6. Optionally, you can adjust the CO setting.
Notes:
1. Use a long nose plier to wiggle free the MAP sensor hose if it is tight.  Do the same for the Right Side TB rubber plug.  If the rubber plug cracks, temporary I will use the 4mm clear hose and cut it short and force in a M4 bolt.
« Reply #21 on: August 16, 2017, 11:38:38 am »
Thanks!
« Reply #22 on: August 16, 2017, 12:13:13 pm »
Very Clever. You continue to Impress. Thanks for This.
I sure wish you had posted this before I spent all that cash on a store bought manometer. Oh Well, the next guy benefits.
Thank You, 2DaMax!
« Reply #23 on: August 16, 2017, 12:21:41 pm »
To give a visual image of what 2DaMax is talking about. It's much more involved and takes longer than pulling out a CarbMate or manometer, but it works and is cheap. The tubing I used was about 20 ft long.
« Reply #24 on: January 10, 2018, 01:23:22 pm »
I performed the TB sync check today. No reason, I did it cause I could...
I used the hose length setup described above, with a small difference: The two hoses from my manometer were of equal length from the meter input to the TB nipple connections, no allowance in the left TB hose length for the branch hose "T" connection to the MAP sensor.
This system worked out fine. I used a "Carbtune Pro" manometer, bought online and setup with a "vacuum restrictor" in each of the two hoses per their instructions. Each of the two included 1/8" hoses measures to 100 cm, and they instruct to place a restrictor in each hose at 10 cm from the end, at the engine connection side. That is, cut 10 cm from each hose end and insert a restrictor there. Then, connect that end to the TB nipple.
The OEM hose from the MAP sensor to the left TB is 3 1/4" long. It's not 1/8" hose, it's something slightly narrower. It's a tighter fit than 1/8" hose. I would replace it with 1/8" hose available everywhere here in the US, *but* if I did that, I would use hose clamps of some sort. Without clamps, it would not be slip-on tight enough for me, to leave it that way permanently.
So, I pulled off the OEM 3 1/4" long hose, and cut a piece of 1/8" hose to that same length. Then I cut that in half and inserted both half pieces to the plastic "T" connector. Then, insert the remaining "T" connector nipple to the left manometer hose end, the end with the restrictor. Then, Hold up the two manometer hoses, and cut left side hose so that both hoses are equal length again, manometer to TB nipple connection. (ie: Do not deduct for MAP sensor branch length of 1/2 of 3 1/4"). Just make the two hoses equal length, end to end,  as they're dangling in front of your eyes.
I noted the Right TB nipple rubber cover has a clamp to keep it in place. The MAP sensor to Left TB hose does not have clamps, it's a tight sliding fit only, at both ends.
On my cycle, a 2016 non-ES model, the right TB is "painted" and so is the reference side. I placed a marked tape piece as a "witness" mark for the screw positions on each side before adjusting anything. The right TB side was set at 1/4 turn out by the factory setting.
I connected the manometer to the TBs, and the MAP sensor to the "T" hose. Started the cycle, gave it a 10 minute idle warmup, and noted that the manometer read at 23 cm / Hg on both sides after the warmup. A balanced reading on both sides, no adjustment needed. I also noted the reading were not level and balanced at cold, just after startup. They became balanced as the cycle warmed up.
Yeah, I turned the left TB screw anyway :)  Left TB reading went up, turned Left TB screw other way, Left TB reading went down. Turned the Left TB screw again, and eyeballed it at "both level", and noted the Left TB was again at the witness mark reading.  Good!
Turned it off and buttoned it back up.
« Last Edit: January 10, 2018, 01:26:38 pm by mebgardner »
Last post August 14, 2011, 10:32:59 pm
by SpeedStar
Last post July 13, 2015, 10:11:52 am
by Ron14S10
Last post January 01, 2013, 02:11:16 pm
by triman11427
Last post January 21, 2015, 12:29:36 pm
Last post March 18, 2018, 08:33:43 am
