Author Topic: How To: Cycle the ABS Pump  (Read 1421 times)
« on: August 02, 2017, 07:04:28 am »
Here's how to use the S10 built in ABS pump cycling feature.
Tools Needed:
1. Jumper wire with both ends stripped.
2. Mini Screw Driver to remove the waterproof rubber bungs.
3. Fully Charged Battery.
3. Locate the 4-way connector under the main seat.
4. Remove the 2 rubber bungs on Blue and Black wire.  Then attach the jumper wire as shown.  The wire diameter of the stripped ends needs to be of a certain size so that they are 'catch' inside the connectors.
5. Set the Kill Switch to OFF
6. Turn the KEY to ON.  Observer that the ABS warning light on the dash is flickering ON and OFF.  If this is not so, the jumper wire is not connected correctly.
7. PRESS and HOLD the START BUTTON for about 4 seconds.
8. Simultaneously Step down on the Rear Brake Pedal and Grab the Front Brake lever.
9. The ABS Pump will first actuate the Front for a few seconds, then the Rear, and then back to the Front.  All done in about 15 seconds.
10. Key Off.  Congrats. ABS Pump cycled.
11. Remove jumper wire.  Replace the 2 bungs to the connector.
12. Enjoy the ride!  Then have a beer.
Purpose:
1. After the brake fluid bleed, some fluids are trapped inside the ABS unit.  This is the only way to move these guys out.
2. Preventive Maintenance.  If the ABS pump is not used for a very long time, it may get stuck and ABS may not actuate when you need it.
3. Some worst case scenario where air gets introduced to the pump and the brake pedal feels like there is no resistance (not woody feeling).  Cycle this to move air out from the ABS unit and you may need to do this more than 10X.
Offline RCinNC
Re: How To: Cycle the ABS Pump
« Reply #1 on: August 02, 2017, 08:13:36 am »
This is a good write up, and I copied it for my service manual, but it's not the only way to cycle the ABS pumps when you're bleeding the brakes.  You can do a first bleed, then ride your bike down a gravel driveway and grab each brake til the ABS pump kicks on, then go back and bleed the brakes again.  It's easier on a loose surface like gravel because you don't have to get going as fast in order to get the ABS to activate when you brake, but it works on the street, too.
2014 Yamaha Super Tenere
2012 Suzuki DL650 (traded)
2004 HD Road King Custom (sold)
2000 Yamaha Road Star 1600 (traded)
1994 Yamaha Virago 1100 (traded)
1982 Honda V45 Sabre (traded)
1984 Kawasaki 440LTD (sold)
« Reply #2 on: August 02, 2017, 08:46:08 am »
Even though there is a sticky about bleeding the ABS brakes, I'll make this a sticky too, because it's clear and focuses on the pump.
Thanks 2daMax,
Online Bryce
  • Ya, Whatever!
« Reply #3 on: August 02, 2017, 09:38:02 am »
on step 4, you can just remove the dummy plug with the 4 rubber plugs as a unit.I used a paperclip bent so it would grab the back and blue wire's pins.
"It sure beats working all week, boozing it up in some smoky bar or sitting around watching the world go to Hell in living color and still ending up, just before payday, flat broke as usual. That's only existing, not really living." - Don Marshall, Cycles South, 1971
'14 Super Ténéré - Team Yamaha Blue
'08 KLR650 - Blue 21
IBA #63421
Offline craigd
« Reply #4 on: August 05, 2017, 08:54:22 pm »
On 2104 and newer models the procedure is a bit simpler.
Jumper the same wires.
Put the kill switch in the off position.
Hold front and rear brakes on.
Turn on the key.
The ABS system will cycle front, rear, front.
Turn off key.
Offline Rockhopper
« Reply #5 on: December 03, 2017, 03:01:39 pm »
So at which point of the bleed process does the pump need to be cycled?
Thanks for the write up. It will come in handy this week :)
2014 Super Tenere
« Reply #6 on: December 05, 2017, 07:11:18 am »
Bleed first. Then cycle. Then bleed again. Done...unless u got air in the ABS pump itself which requires mulitple loops of bleed, cycling until all air is purged.
Offline Kevs
« Reply #7 on: July 09, 2018, 08:00:46 am »
Turn on the key.
Turn off key.
similar procedure for pre-2014 models (mine is 2012's), & which had swap to a later FJR Starter-Kill Switch cluster.
did what @2daMax mentioned, but I bleed, cycled then bleed again.
took the chance to flush my rear since it was last done in '15 IIRC..
the rear brake reservoir's diaphragm was slightly distorted but finger tweak back to shape.
after putting back everything, discover the front brake reservoir is slightly blowing bubbles when I squeeze the lever as I mist the area with water to wash off any residue.
reopen the cover, clean everything & out back. mist then squeeze lever again, bubbles still appearing.
wipe off excess water & try again.. so far so gd & brake tension is back..
Disclaimer:
The above information is obtained from third party sources for which I assume no responsibility.
While there is no reason to believe that the information is unreliable, no liability is accepted for any errors or inaccuracies.™®©
Last post May 01, 2016, 11:05:02 am
by ace50
Last post January 28, 2015, 02:14:24 pm
by dirtdigger570
Last post April 22, 2015, 05:53:26 pm
by ridefire
Last post June 26, 2017, 11:38:37 am
by msch
Last post October 26, 2017, 03:47:48 pm
by Crew Chief
